Old 02-01-2002, 04:22 PM   #1
NiNJA
NiNJA is an unknown quantity at this point
Send a message via AIM to NiNJA
Hey all,
I just got the APEXi N1 Dual and was wonderin what size hi-flow cat would I use on it? A 2.5inch or 3inch cat? Sorry if this has been posted before, I'm busy installing my Intrax springs and KYB shocks...
            Thanks In Advance
NiNJA is offline   Reply With Quote
Old 02-01-2002, 08:39 PM   #2
S14KAT
S14KAT is an unknown quantity at this point
To be honest with you I have the Random Tech cat and they don't offer(or at least I don't think they do)different diameters in there cats.  Other manufacturers may be different, but 2.5 inch is the only size that I'm aware of.
S14KAT is offline   Reply With Quote
Old 02-01-2002, 08:46 PM   #3
Nismos14
Nismos14's Avatar
Nismos14 is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from S14KAT on 10:39 pm on Feb. 1, 2002
To be honest with you I have the Random Tech cat and they don't offer(or at least I don't think they do)different diameters in there cats. Other manufacturers may be different, but 2.5 inch is the only size that I'm aware of.</td></tr></table><span id='postcolor'>
did it make a big difference in performance?
Nismos14 is offline   Reply With Quote
Old 02-02-2002, 09:27 AM   #4
NiNJA
I think im gonna go with the Carsound cat, it comes in 2, 2.25, 2.5 and 3inch .
Old 02-02-2002, 10:30 PM   #5
allmotorKA
allmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really nice
You CAN get 3&quot; diameter inlet/outlet cats from Random instead of the 2-1/2&quot; diameter they list for the 240SX. For the 89-97 240SX, Random lists the 2-1/2&quot; diameter cat as part number as 822530...but according to Random, part number 823030 is a 3&quot; diameter cat which was made for the Maxima, but will work for the 240SX as well.
If the N1 dual has a 3&quot; inlet, I would recommend the 3&quot; Random Tech Cat since the Random Cats have slip type flanges. What I mean is that the mounting flange of the cat is free to slide and rotate on the inlet and outlet pipes of the cat. So if you get the 2-1/2&quot; Random Cat, the outlet pipe may be swallowed by the N1 exhaust making it difficult to seal properly without a steel reinforced exhaust gasket.
allmotorKA is offline   Reply With Quote
Old 02-03-2002, 09:07 AM   #6
NiNJA
Well to my further research, I think the APEXi N1 Dual is 2.5inch in diameter, and I heard the APEXi N1 Single is 3inch with a 2.5inch converter that you can take off when you go turbo ?? (Not sure on that, if someone can explain for me) ....I'm staying N/A for a while so I'm gonna stick with 2.5inch hi-flow cat...
