Ok how exactly do you go about removing the rear hub on a 96 240, i want to make sure i do it right before i go and break something and then have to spend more money to fix it..
Take off wheel
take off caliper take off rotor take off cotter pin for axle take off rear bub nut (36mm) get a piece of wood and lay it out the spindle, and hammer it until the axle moves enough to remove, slide it out In back of the spindle with be (iirc) 4 17mm bolts, remove those, and hub comes off the spindle. its very late, so if I miss any steps, sorry |
ok i cant push the axle back far enough to pop it out, but i can get the 4 bolts off anyway will this do anything diffrent or will it still come off?
![]() Join Date: May 2002
Are you guys saying you have to remove the four bolts on the axle side of the hubs? Or are we talking controll arm bolts here? Cause I got both mine off 3 days ago without touching the bolts on the spindle.
I took mine off to have my bushing sleeves pressed out by a machine shop. They are a real bitch to get out. What are you working on? Joey
Exceed 400x200 size limit |
