Old 03-06-2007, 12:09 PM   #1
defiantmofo
defiantmofo is a well-known jackass
Fuel Pump/Ecu problems.
I'm trying to start my S13 with S13 SR, and im having a couple issues. The engine would crank and crank but not turn over. We figured out the Walboro wasnt getting any power, so we pulled out the volt meter and test light and weren't getting anything. Pulled the fuel pump relay out, hooked it up to power and ground and it clicked. So relay is good. Put relay back in, and it still doesnt work. We made a jumper cable to act like a relay, connected it to the fuse block in the engine bay, and we get power to the fuel pump. Also before when i was testing, if i put the car in the on position(not started) the powerFC Commander would light up. Now, it does not. Im thinking that these problems are related, and was looking for some help. Fuses seem good in the engine bay, we swaped green relays with no luck, im now just scanning over the loom looking for things we missed. any ideas?
thanks,
bill
defiantmofo is offline   Reply With Quote
