Old 04-12-2007, 09:26 PM   #1
Croan
Croan is just really niceCroan is just really niceCroan is just really niceCroan is just really niceCroan is just really niceCroan is just really niceCroan is just really niceCroan is just really nice
Question Coolant Resivor Q's
does the bottle or the hose need to be at any certain hight, i.e. above the radiator cap, or below the radiator cap, does the hose have to droop down below the cap level before it goes into the reservoir? does the reservoir need to be any certain capacity or volume? is there a minimum or maximum amount of extra coolant that i should have.
Croan is offline   Reply With Quote
Old 04-12-2007, 09:31 PM   #2
ladiesman8527
ladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enough
why dont u just get a oem resevoir, mount it, and run the tube from the rad to the resevoir like it was from the factory?
ladiesman8527 is offline   Reply With Quote
Old 04-12-2007, 09:33 PM   #3
Croan
i could do that
Old 04-12-2007, 09:37 PM   #4
Addicted2Kouki
Addicted2Kouki's Avatar
Addicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfection
+1
but what do i know. i leave my coolant resevoir empty cuz it all leaks out anyways. [stupid hole]
Originally Posted by coreansurfer View Post
zenki's are for poors and lames
with the exception of norm who is big ballin
FS:CUSCO,GREDDY,KA-Tparts
Addicted2Kouki is offline   Reply With Quote
Old 04-12-2007, 09:40 PM   #5
ladiesman8527
is the nipple right below the cap on your radiator plugged or left open or what?
Old 04-12-2007, 09:41 PM   #6
slownslurious
slownslurious has made poor choicesslownslurious has made poor choicesslownslurious has made poor choicesslownslurious has made poor choicesslownslurious has made poor choicesslownslurious has made poor choices
autozone has two different sized ones that both fit and both work. they are like $10.
courtesy nissan has the real thing for substantially more.
they work the same
you need it.
why jury rig something
slownslurious is offline   Reply With Quote
Old 04-12-2007, 09:43 PM   #7
Croan
it still has the hose to the external reservoir on it, capped off
Old 04-12-2007, 09:46 PM   #8
ladiesman8527
Originally Posted by Croan
it still has the hose to the external reservoir on it, but instead of a reservoir on the other end of the tube theres a bolt electrical taped to the end of it ha ha
thats not good. when the coolant gets hot it expands and needs some place to go. otherwise, excess pressure is gonna build up.
Old 04-12-2007, 09:53 PM   #9
Croan
yea, so ive read. but as far as my questions are concerned?
is there a minimum or maximum amount of extra coolant that i should have?
Old 04-12-2007, 10:03 PM   #10
ladiesman8527
yea, so ive read. i dont want to uncap the end of the hose with the bolt on it because i dont want to buy antifreeze yet, ill just hook up a bottle to it. but as far as my questions are concerned?
"does the reservoir need to be any certain capacity or volume?"
"is there a minimum or maximum amount of extra coolant that i should have?"
"are the potential risks of just not having a reservoir at all?" besides pressure building up and popping the hose or shooting the bolt out through the engine killing me instantly.
if theres no way for the radiator to release pressure, it could burst. the hoses could burst. your cooling system would not be very efficient. i wouldn't worry about trying to make ur own. just get a hold of an OEM reservoir which is already properly sized and what not.
Old 04-12-2007, 10:09 PM   #11
Croan
aww. no fun. thanks for all your info but im going to do it my way, stay close to the OEM resivor volume, mount the new tank somewhere out of the way and clean, and have the hose droop down past the radiator cap,thanks ladiesman8527, slownslurious, and Addicted2Kouki.
