Old 06-01-2007, 12:24 PM   #1
Disturbe240
Disturbe240 is on the path to ruinDisturbe240 is on the path to ruin
walbro
do you have to change the fuse for the pump and put a biger une, because mine keeps blowing up :hammer:
Disturbe240 is offline   Reply With Quote
Old 06-01-2007, 12:34 PM   #2
sleepy_s13
sleepy_s13's Avatar
sleepy_s13 is a splendid one to beholdsleepy_s13 is a splendid one to beholdsleepy_s13 is a splendid one to beholdsleepy_s13 is a splendid one to beholdsleepy_s13 is a splendid one to beholdsleepy_s13 is a splendid one to beholdsleepy_s13 is a splendid one to beholdsleepy_s13 is a splendid one to beholdsleepy_s13 is a splendid one to beholdsleepy_s13 is a splendid one to beholdsleepy_s13 is a splendid one to behold
check your grounds.
K:\pics\Cars\new sig bridge copy.jpg
sleepy_s13 is offline   Reply With Quote
Old 06-01-2007, 12:35 PM   #3
ch1873857
ch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the rough
Send a message via AIM to ch1873857
you hooked pos to pos neg to neg right?
ch1873857 is offline   Reply With Quote
Old 06-01-2007, 12:44 PM   #4
Disturbe240
yes pos to pos and neg to neg the car was runing fine went for a little ride and wen the car got in boost the fuse pop
Old 06-01-2007, 12:57 PM   #5
ecuastyle84
ecuastyle84's Avatar
ecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to all
Send a message via AIM to ecuastyle84
sounds like you have a short some where. check your wiring and see if it is grounding out somewhere.
ecuastyle84 is offline   Reply With Quote
Old 06-01-2007, 01:04 PM   #6
swayray
swayray's Avatar
swayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfection
heheh... the other guy at the other tread has the same problem but w/ a stock one...
check to see if the baffels in your gas tank is loose... if it is... then its what's causing your short...
otherwise... check the two wires you hooked up onto your fuel pump... its best to use terminal connectors on those rather than electrical tape....
make sure you do not have a fake walbro fuel pump... check for authenticity... the fake one give you problems like this all the time...
http://www.thenismoshop.com
swayray is offline   Reply With Quote
Old 06-01-2007, 02:11 PM   #7
Disturbe240
i just pull out the pump and put it back in end now it works just fine, oune of the wire must have been loost or something.now reqdy for more boost!
Old 06-01-2007, 02:34 PM   #8
swayray
swayray's Avatar
ok... but if you have the same problem again... you know where to look...
btw... no... you use the same size fuse....
