Old 06-04-2007, 12:48 PM   #1
nismosil40zx
nismosil40zx is a well-known jackass
Send a message via AIM to nismosil40zx
SR Dies on Decel....Also low volts
Im having 2 issues...
1. When Im decelling at low rpm the car tends to die like it wont hold a idle. what can be the cause of this (bad IAC)
2. When I start my car its charging voltage is 14 and the ECU is reading 12.6 Volts good as I drive the charging drops to13.0 to 13.5 and the ecu is reading 11.5 to 11.8v. sometimes low also I am on a ka Alternater. Should I through more grounds on or what?
sr20det redtop
Mods are
SC-61 top mount, 370cc (7psi),SAFCII, stock ka MAF I just put it together could this be the cause, my 300zx MAF will be here today, Injectors next week.....Never did it before before i put this stuff on with the decel problem.
nismosil40zx is offline   Reply With Quote
