Old 06-26-2007, 01:28 PM   #1
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
SR warmup problems
does anyone ever have problems with their SR when starting their car up.
mine bogs when it starts up cold then after it warms up to 68-75 degrees it runs ok. its pretty warm over here like 80-90 degrees outside and my sr bogs when its cold when starting up around 30-55 degrees.
started doing that when i took my FMIC out to install a push electric fan in the front of the radiator. FMIC was properly installed back on and tightened up so there are no boost leaks.
also running a z32 maf. <------ could it be the problem. never happen when i install the z32 maf. its caliberated with the Power FC to work properly.
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 06-26-2007, 01:59 PM   #2
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
check the idle air control valve air regulator valve, it's the black square shaped doohicky. one side is black the other's aluminum, it has a vacuum hose on each end, one goes to the idle air control valve, the other goes on a bung in the intercooler piping before the throttle body. it's job is to allow more air to the iac during cold starts. gl
Dave
RB25 280z GT30/76R 441hp/381tq 11.9@125
Z U L8R is offline   Reply With Quote
Old 06-26-2007, 02:04 PM   #3
s13silvia123
thanks i'll check on that when i have time. any more suggestions could be helpful.
Old 06-26-2007, 02:34 PM   #4
SSC299
SSC299's Avatar
SSC299 is an unknown quantity at this point
Send a message via AIM to SSC299
iacv should do it. that happened to me when I first put in my sr. I also had a vacuum leak (tiny leak) that would close when everything was hot so the car would run fine after warming up but sucked at idle and between shifts when cold (mainly at night around 45-50 degrees).
- always something
SSC299 is offline   Reply With Quote
Old 06-26-2007, 02:45 PM   #5
s13silvia123
so if its the IAVC right. i have to clean it and use new vacum lines rite.
