Clean 91 s13 sr20det
White 91 s13 sr20det
229,000 miles on Body - Approx 46,000 miles on Motor swap All Parts listed below were purchase new and installed from February 07 till present day. 95% of all parts installed have less than 5k on them! Have over $11,000 invested with receipts - Asking $6,500 OBO -This is my daily driver. Selling vehicle because I’m getting married and looking to purchase a house. Interior: Coupe dash with working JDM HUD, couple minor cracks in dash Extra HB dash with 2 hairline cracks (tried to adapt for HUD) Newer OEM carpet (charcoal) Celica GT seats (Black) CD player (MP3, WMA) Kenwood speakers in all 4 corners OEM Shift Boot (New) Exterior: Borbet 15x7 +35 aluminum five spoke rims wrapped in NEW Yokohama directional tires (H rated ) JDM Silvia wing Sun Roof (No leaks) Engine: JDM SR20DET Full Engine Swap (Swapped by Eugene) Head/block was milled by Abacus Racing. (Cylinder walls, piston tops and valves looked great) ARP Head Studs (Installed by Abacus Racing) Cometic 1.01 Metal Head Gasket (Installed by Abacus Racing) NGK Iridium Spark Plugs Heat 6 Greddy Rocker Arm Stoppers Hayden Electric Fan: 16” 1500 CFM KOYO Aluminum Radiator with Greddy Cap 18.5 psi Nismo Thermostat SAMCO Silicone Radiator Hoses Hybrid Development Intercooler Kit Enjuku racing Hot Pipe with HKS BOV Flange HKS SSQV Blow-off Value Walbro High Pressure 255ltr/hr Fuel Pump New 300zx Fuel Filter Rebuilt T-25 Power Steering Pump Replaced New Water Pump Turbonetic T-Clamps Transmission: Manual 5 Speed Agency Power Stainless Clutch Line B&M Short Shifter Fidanza Lightweight Flywheel SPEC Stage 3 Clutch New Slave Cylinder Engine Accessories/ Maintenance: CUSCO Front OS Strut Bar Odessey Lightweight Race Battery (11 Lbs) Megan Racing Brake Cylinder Heat Shield Blitz LM Air Filter Peak Performance Magnetic Oil Drain Plug Mr Gasket Exhaust Manifold (Copper) OEM Turbo Inlet Gasket OEM Turbo Outlet Gasket OEM Value Cover Gasket Complete Belt Set Nismo Motor mounts and Transmission Mount New Heater Hoses Peak Performance Thermal Intake Gasket Circuit Sport Oil Catch Can New Fuel Lines and vacuum lines Pipe Couplers were all replaced Changed Transmission fluid to Full Synthetic Running Mobile 1 10w-30 Full Synthetic Suspension: KYB AGX Adjustable Struts TEIN S Tech Lowering Springs Power Brace Weld In New Outer/Inner Tie Rods (Installed by All Aspect Motors) New Steering rack (Installed by All Aspect Motors) Exhaust: Circuit Sport O2 Elimination Down pipe Megan Racing Test Pipe Circuit Sport 3” DT Cat Back Exhaust Circuit Sport Exhaust Hanger Bushings Ichiba Turbo Manifold (identical to Tomei Expreme) OEM Fatty o2 Sensor Electronics: Greddy Profec Spec B-II Electronic Boost Controller Apex-I Auto Turbo Timer- Silver with harness Parts given with sale: Z32 4 piston Aluminum 30mm front brakes with Endless Racing Pads Nismo 60mm Extended studs H4 Conversion Lights Contact Information: James [email protected] Cell- 757-971-1495 ![]() ![]() ![]() ![]() ![]() ![]() Last edited by 2l84u; 06-06-2007 at 02:38 PM.. Reason: price drop |
