Old 07-05-2007, 07:50 PM   #1
JDM SiL80
JDM SiL80 is a jewel in the roughJDM SiL80 is a jewel in the roughJDM SiL80 is a jewel in the roughJDM SiL80 is a jewel in the roughJDM SiL80 is a jewel in the roughJDM SiL80 is a jewel in the roughJDM SiL80 is a jewel in the roughJDM SiL80 is a jewel in the rough
Engine Trouble - w/ VIDEO!
Well everytime I start the car and try to move it, it just boggs. It does this for some time till it gets alittle hot and then it runs fine. It is a stock dual cam KA with 105k miles on it.
Here is the vid so you know exaclty what I mean.
When I accelerate just a tiny tiny bit the revs just fall to like 500. When I release the gas is when it jumps back up to idle.
Has anyone had this problem or know what it could be?
Thanks in advanced guys!
JDM SiL80 is offline   Reply With Quote
Old 07-07-2007, 09:15 PM   #2
JDM SiL80
Anyone? lol any help is really appreciated.
Old 07-07-2007, 09:22 PM   #3
bZeRk187
bZeRk187's Avatar
bZeRk187 is an unknown quantity at this point
Send a message via MSN to bZeRk187
Muffler bearings are worn out. I'm sure someone on Zilvia has the hook up on a pair. GL
bZeRk187 is offline   Reply With Quote
Old 07-07-2007, 09:28 PM   #4
GSXRJJordan
GSXRJJordan's Avatar
muffler bearings! lol coming from the guy with 9 posts and a red square.
looks like your idle control is fine, cause it keeps jumping back up to idle... I really don't know what it is, short of a weird vacuum leak... did you just pick up the car, or has it steadily gotten worse?
Old 07-07-2007, 10:12 PM   #5
bZeRk187
bZeRk187's Avatar
Seems like you provided just as much help.
And WTF is wrong with suggesting muffler bearings? Have you checked yours lately bitch?
Old 07-07-2007, 11:31 PM   #6
s13_redSILVIA
s13_redSILVIA has a brilliant futures13_redSILVIA has a brilliant futures13_redSILVIA has a brilliant futures13_redSILVIA has a brilliant futures13_redSILVIA has a brilliant futures13_redSILVIA has a brilliant futures13_redSILVIA has a brilliant futures13_redSILVIA has a brilliant futures13_redSILVIA has a brilliant futures13_redSILVIA has a brilliant futures13_redSILVIA has a brilliant future
Send a message via AIM to s13_redSILVIA
car shakes like that in idle??...well if it is i hav same problem cuhz my dads a mechanic and he told that is a bad injector running on 3 cyl...hope this helps
s13_redSILVIA is offline   Reply With Quote
Old 07-08-2007, 01:21 AM   #7
projekt_s13
projekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfection
Send a message via AIM to projekt_s13
It sounded like you are miss firing, I slightly have the same problem. When I just start the car up and drive off it bogs a bit dropping about 500-700 rpms from where im at (like if im at 2500rpm it drops to about 2k). This only happens for about 2 minutes until the car warms up, weird thing is that if i push the clutch in and accelerate the rpm climb up like nothings wrong.
It used to bog alot but I used seafoam and it made it better.
But yea It might be your Muffler bearings, lol
projekt_s13 is offline   Reply With Quote
Old 07-08-2007, 01:26 AM   #8
SnakeKack
SnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of light
Send a message via AIM to SnakeKack
Do a tune up and see what happens.
SnakeKack is offline   Reply With Quote
Old 07-08-2007, 03:36 AM   #9
nassin31spr
nassin31spr's Avatar
nassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to behold
Do a tune up, do a compression test and see if your car jumped timing. It almost sounds like some metal on metal contact. Take off the valve cover and check the chain guide.
"Home is where the armor is"
nassin31spr is offline   Reply With Quote
