Old 09-05-2007, 11:09 PM   #1
2plus4plus0eq6
2plus4plus0eq6 is making his/her stupidity well-known2plus4plus0eq6 is making his/her stupidity well-known2plus4plus0eq6 is making his/her stupidity well-known2plus4plus0eq6 is making his/her stupidity well-known
SR SR safe to drive in winter?
I WAS in the process of doing my sr swap in May, but ran out of money to finish it after I found out I blew my stock turbo. Now I am considering fixing it all right now so I can drive around for at least a few months before it snows.
I need to know if its OK to drive my car in the winter - even if its snowing. I am talking about temperatures as low as -15 celsius.
btw.. its got a fmic
Thanks
2plus4plus0eq6 is offline   Reply With Quote
Old 09-05-2007, 11:13 PM   #2
Dousan_PG
Dousan_PG's Avatar
no its not
it doesnt snow in japan
regular 75 F year round
there's no snow there
Aaron
Pink GodziRa
Old 09-05-2007, 11:18 PM   #3
BoostGetsULaid
BoostGetsULaid is making a name for him/her selfBoostGetsULaid is making a name for him/her selfBoostGetsULaid is making a name for him/her self
its a RWD car. in the snow i wouldnt drive a rwd car with studs and chains.
BoostGetsULaid is offline   Reply With Quote
Old 09-05-2007, 11:19 PM   #4
mRclARK1
mRclARK1's Avatar
mRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfection
You can drive it... I did it (VERY occasionally on warmer days when I had no choice) but it's not going to like it, and neither are you.
mRclARK1 is offline   Reply With Quote
Old 09-05-2007, 11:28 PM   #5
2plus4plus0eq6
I don't want to drive it in the winter, but its kinda one of those 'no choice' things. Its been driven in the winter before, but not since the SR swap. Just gotta put sandbags in the back because of the RWD.
Do you mind explaining to me what its like MrClark?
Does it not start up right away or have a rough idle when cold? Should I be worried because I have a fmic?
Old 09-05-2007, 11:30 PM   #6
lflkajfj12123
bigger wheels, grip tires, lots of sand bags, easy on the throttle and your fine
just make sure you have antifreeze in it before winter starts and turbo cars love cold air don't worry about the fmic its meant to be cool
Old 09-05-2007, 11:31 PM   #7
eastcoastS14
eastcoastS14's Avatar
my SR wouldnt even crank over in the cold weather
eastcoastS14 is offline   Reply With Quote
Old 09-05-2007, 11:48 PM   #8
mRclARK1
mRclARK1's Avatar
I didn't have ANYTHING in the rear... so I slid around like a mofo. If you MUST drive it (You probably have a couple months at least till the really cold part of winter hits... bust your ass and see if you can afford a POS that will at least last out the December, January, February, and March stretch since it's the worst part) then just take it carefully. Especially no fast turns... I slid out and across the intersection onto the otherside of the boulevard (sp?) once because I took a turn too quick and lost traction. Trust me... it happens even easier then you think it will. haha
Also, park indoors whenever possible at least, heated is even better, and let your car get to operating temp before you take it out of the garage into the cold. That helps a lot.
Old 09-06-2007, 12:48 AM   #9
HalveBlue
HalveBlue's Avatar
HalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond repute
240's are fine in the winter...
as long as you don't take it above 2 mph.
Seriously, driving my 240 for 15 minutes in the winter time was more exhausting than a road trip from LA to Salt Lake.
As long as you treat her with respect you should be fine. Don't do anything stupid and learn to drive in the snow in an open, empty parking lot where you don't have to worry about wrecking anything. Take your car out on the first day it snows and see when it looses traction.
Not the preferred car for winter driving, but you gotta do what you gotta do.
Good luck, stay safe.
HalveBlue is offline   Reply With Quote
Old 09-06-2007, 12:54 AM   #10
azndoc
azndoc's Avatar
Trader Rating: (47)
Feedback Score: 47 reviews
Well if its got a FMIC then it's no good then.
Nah your fine dude.
It's good all 4 seasons.
Old 09-06-2007, 01:41 AM   #11
frosti108
frosti108 is just really nicefrosti108 is just really nicefrosti108 is just really nicefrosti108 is just really nicefrosti108 is just really nicefrosti108 is just really nicefrosti108 is just really nicefrosti108 is just really nice
Send a message via AIM to frosti108
id imagine it would be ok to drive. same as any other turbo motor. i would just make sure to let it warm up for a while before driving...
as for rwd in snow... yes it can get wild. but its surely possible. ive driven my 92 ka hatch in the winter and an 87 mazda b2000 mini truck, also my old 82 2wd s-10 . never bothered with any sandbads or anything and i did fine with all 3. just play it safe safe safe. most people get nabbed when they understeer into a curb. i gotta admit i bent a rim once on the curb in my mazda truck from doing that!
Goodnight
frosti108 is offline   Reply With Quote
Old 09-06-2007, 02:07 AM   #12
xanavi_D
xanavi_D is on a distinguished road
if you can try to garage it during the night, a friend of mine had his tranny freeze so bad in colorado that it got fucked up and he had to get a new one.
xanavi_D is offline   Reply With Quote
Old 09-06-2007, 05:57 AM   #13
spool_sample
spool_sample's Avatar
spool_sample has a reputation beyond reputespool_sample has a reputation beyond reputespool_sample has a reputation beyond reputespool_sample has a reputation beyond reputespool_sample has a reputation beyond reputespool_sample has a reputation beyond reputespool_sample has a reputation beyond reputespool_sample has a reputation beyond reputespool_sample has a reputation beyond reputespool_sample has a reputation beyond reputespool_sample has a reputation beyond repute
Actually, for snow, you want SKINNY tires. Big wheels and tires just "float" on top of snow... look at WRC cars and you'll see what I mean.
spool_sample is offline   Reply With Quote
Old 09-06-2007, 07:32 AM   #14
garagelu
Trader Rating: (60)
garagelu is on a distinguished road
Feedback Score: 60 reviews
if you have a nice 240sx with a sr20, why take the risk? Is it really worth all the trouble? There has to be other alternatives. You may regret it when the rear end comes around and slides into a ditch. Think about it long and hard.
garagelu is offline   Reply With Quote
Old 09-06-2007, 07:52 AM   #15
djcobra
djcobra's Avatar
djcobra is making a name for him/her selfdjcobra is making a name for him/her selfdjcobra is making a name for him/her self
You guys haven't seen the weather up north, CANADA! I've been driving my SR car for 2 years in -30C and below weather. 'We' haven't had any problems, as long as you start the car and warm it up for a good 10-15 min and just be easy on the throttle. They're alot of SR owners In Calgary, and in Edmonton, Alberta, and trust me the Winters are harsh! Get a good set of winter tires and you'll be fine, no need for chains, argh! Having the car in the garage during the night would help, but i've seen my friends leave their SR power'd RiCE outside and starts fine. Might want to invest in a Romote Starter? also comes in handy as a Turbo timer. I have a CompuSTAR, I don't know if you Americans have heard of that... Regardless if you have a FMIC or SMIC that shouldn't be a problem at all. Anyways, drive safe and don't rush in the snow, I found to have more control with my RWD than any of my previous FWD cars... Maybe its the way we Canadians Drive haha.... good luck! DoRiFto!
djcobra is offline   Reply With Quote
Old 09-06-2007, 08:08 AM   #16
Silverbullet
Silverbullet's Avatar
Silverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really nice
Send a message via AIM to Silverbullet
driving it in the snow is when it gets fun. You can get side ways just with a tap of the gas and all the cars around you will slow down because they think your out of control and about to crash LOL. I have spun out a couple times in bad spots though, so ya becareful of what you do.
HouseBuyers365.com
Originally Posted by Flybert
Go back to whatever Honda forum you came from.
Silverbullet is offline   Reply With Quote
Old 09-06-2007, 08:33 AM   #17
glitched
glitched is an unknown quantity at this point
Send a message via AIM to glitched
wow, these kinds of threads really get me. "i wouldnt even drive a RWD car with chains" ???
as long as you get a set of dedicated SNOW tires on stock wheels (dont put them on wide summer wheels) and a LSD you should be fine. i cannont stress enough the NEED for dedicated snow tires here! gets some practice so that you are comfortable while out of control i.e. you dont panic.
That night we got so much snow that i was plowing snow with my front lip... never got stuck once. Havent ever spun out on snow tires either. 3 years of winter driving in my 240 and now I look forward to some snow driving in the 240
glitched is offline   Reply With Quote
Old 09-06-2007, 08:37 AM   #18
unicoladron
unicoladron's Avatar
unicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choices
if you're concerned about spinning or you dtend to have a heavy foot the tires turn down your boost too. if you don't want to invest in a boost controller, just hook the wastegate straight to a nipple on your cold side and it'll be ~7psi as opposed to stock of ~11 (if you're using the factory soolenoid). also like the guys said, get yourself some bridgestone blizzaks on your steelies if you have em. if you got coilovers definitely set yourself to 4x4 mode so you don't drag your aero in the snow. i plan on driving my sr20 alllllll winter with some blizzaks on the rear and sandbags.
1993 KA24DE for sale with 180k..running when pulled.... need to get rid of ASAP...i'm moving
unicoladron is offline   Reply With Quote
Old 09-06-2007, 08:37 AM   #19
2plus4plus0eq6
Thanks for the comments so far.
I have actually driven my car for the past 3 winters so I am somewhat pro at drifting now hah. I have a good set of winter tires and a remote start for my car. I was just worried about the SR engine and fmic.
If you guys say its OK to drive then, I will really think about getting it back on the road soon then.
Old 09-06-2007, 09:00 AM   #20
JaeTea
JaeTea's Avatar
JaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really nice
Send a message via AIM to JaeTea
I have a Subaru and without winter tires the thing is NOT fun to drive in the snow.
I got stuck trying to make it up a hill.
I couldn't imagine trying to drive a RWD car with street tires in the snow. Maybe lower you tire pressure to like 10 psi.
JaeTea is offline   Reply With Quote
Old 09-06-2007, 09:30 AM   #21
lflkajfj12123
gotcha, makes sense was thinking wider wheels for more traction but you wouldn't fit snow tires on those. i've always driven with just steelies and 295's in the winter
Old 09-06-2007, 12:30 PM   #22
GRIPPY
GRIPPY is a well-known jackass
My cousin drive his SR all last winter, even in minus 30* celcius!
GRIPPY is offline   Reply With Quote
Old 09-06-2007, 12:35 PM   #23
mRclARK1
mRclARK1's Avatar
Basically if you don't have to drive it: Then don't.
If you must, then be careful, and baby your motor as much as you can. Especially since I assume it's a bit of a project anyway.
Old 09-06-2007, 01:10 PM   #24
240truk
240truk's Avatar
240truk has a spectacular aura about240truk has a spectacular aura about240truk has a spectacular aura about240truk has a spectacular aura about240truk has a spectacular aura about240truk has a spectacular aura about
KAs are almost more dangerous on slippery surfaces because of the low-end torque. SR should be no problem as long as your not trying to stomp on it. but why not??? driving with no traction is so much fun!!!!
240truk is offline   Reply With Quote
Old 09-06-2007, 01:17 PM   #25
jskateborders
jskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond repute
Send a message via AIM to jskateborders
I always used to look foreward to the snow, and drove my 240 all the time (which wasnt my DD at the time.) Even on cheap tires, I never lost control. I love snow cause you can go find an abandoned parking lot and drift without any wear on your car!!!
jskateborders is offline   Reply With Quote
Old 09-06-2007, 01:29 PM   #26
celica3sgte94
celica3sgte94 will become famous soon enoughcelica3sgte94 will become famous soon enoughcelica3sgte94 will become famous soon enough
Originally Posted by Dousan_PG View Post
no its not
dude your dumb man it snow in japan too and 75F year around WOW seriously u kno how hot it gets in the summer over there and how cold it is in winter.i wish it was 75F all year around lol
celica3sgte94 is offline   Reply With Quote
Old 09-06-2007, 02:10 PM   #27
Irukandji
Have you ever heard of sarcasm?
Old 09-06-2007, 03:07 PM   #28
Slow*Jim
Slow*Jim has a little shameless behavior in the past
no its not
You sure about that?
http://en.wikipedia.org/wiki/Sapporo_Snow_Festival
Slow*Jim is offline   Reply With Quote
Old 09-06-2007, 03:24 PM   #29
celica3sgte94
i wish it didnt snow over there cause snow mess me up all the time when im down there in the winter time cant do shit
Old 09-06-2007, 06:13 PM   #30
lflkajfj12123
LOL man you guys are daft
