![]() Join Date: Jan 2006
Trader Rating: (41)
![]() Feedback Score: 41 reviews
95 Automatic 240 Throwing 11 CEL Codes
My 96 Auto 240 is throwing 11 CEL codes... i really dont wanna replace everything so i wanted to post this up and see if any of you guys knew if one thing was causing something else to come up
P0105 - Absolute Pressure Sensor P0446 - EVAP Canister Vent Control Valve P0135 - Front O2 P0120 - TPS P1105 - Manifold Absolute Pressure (MAP)/ Barometric Pressure (BARO) Switch Solenoid Valve P0136 - Rear O2 P0443 - EVAP Control Valve P0505- IACV P1705 - TPS P1400 - EGRC Solenoid Valve P1441 - Vacuum Cut Bypass Valve Let me know if there's any easy fixes for these problems...thanks!!! Last edited by krappy; 10-24-2007 at 02:38 PM.. |
Does the car run with all these codes being thrown? The fact that 240's use a MAF sensor not MAP sensor kinda throws me off ... possibly bad ECU?
With those codes being thrown .. IACV/TPS .. your car would run like complete shit. |
![]() Join Date: Sep 2006
have you tryed clearing out the codes and seeing which come back?
P0135 - Front O2- cheep P0136 - Rear O2-cheep P0505- IACV- get a rag and clean it its on the passenger side back of motor if im not mistaken check fsm to be sure the others im not sure about. |
#5 | |
![]() Join Date: Dec 2002
And FYI to Sidewayzzz- The MAP-BARO sensor is only used for pressure readings for the EVAP canister. Has nothing to do with engine operation.
Alright, well then you're screwed.
Seriously, there's virtually no way to get all those codes unless you have a major vacuum leak, since most the EVAP stuff is vacuum based. Since it's running rough, check that first.
