Old 10-25-2007, 11:29 AM   #1
SHIFT_*grind*
SHIFT_*grind*'s Avatar
SHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfection
S13 A-pillar...same on coupe/hatch/convertible?
Wasn't sure whether or not this should go in Tech Talk, or Chat (since it's not that technical), but does anyone know if the a-pillar is different between the coupe/hatch, and the convertible? I bought a single a-pillar gauge pod from one of those Ebay companies, simple black plastic, and it doesn't fit on my 'vert. Doesn't lay flat to the pillar.
I thought they just sent me the wrong part until I saw a picture of someone's S13 coupe on here, with gauges on the a-pillar, and where the pod met the pillar, it looked to be the same shape as the one they shipped me. So I'm wondering, if I order another one (possibly from a different company), whether or not I'm just gonna end up with something else that doesn't fit
SHIFT_*grind* is offline   Reply With Quote
Old 10-25-2007, 11:30 AM   #2
MavericStephenc
MavericStephenc's Avatar
MavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfection
Send a message via AIM to MavericStephenc
yes cept vert me thinks, where did you order it from?
That kind of attitude is SHIT. People with that kind of complacent outlook on law and government are the bane of this country's existence. -Thesquidd
Boycott Berkeley and code pink
MavericStephenc is offline   Reply With Quote
Old 10-25-2007, 11:34 AM   #3
SHIFT_*grind*
One of those Ebay ricer companies, GlowShift I think. Didn't much care because I didn't think they could screw up a piece of black plastic
Are you saying you think the 'vert is different?
Old 10-25-2007, 11:36 AM   #4
DOOK
DOOK's Avatar
my gauge pod isn't the same shape as the a pillar trim, I just made it work. if you're any good with fiberglass you can fiberglass over it all and smooth and paint it, just do the same to your passenger side but without the pod.
<------ Grumpy Old Asshole
DOOK is offline   Reply With Quote
Old 10-25-2007, 11:38 AM   #5
MavericStephenc
yes, although i have never compared side by side, but in any case I would recomend autometer if you plan to get another one 25$
Old 10-25-2007, 11:41 AM   #6
SHIFT_*grind*
I've never worked with fiberglass. I trimmed down the sides of the pod a little and it lays a little flatter, but it'll still look bad if I actually mount it.
Maybe I'll try an Autometer. Thanks
edit: Autometer only has one part number for the S13...
Old 10-25-2007, 11:47 AM   #7
MavericStephenc
call up cip motorsports and ask Jeff he should know cause they sell' em'
EDIT: they should fit fine. it does not replace the whole pillar
Old 10-25-2007, 11:57 AM   #8
SHIFT_*grind*
I just found some info saying that the 'vert A-pillars are flatter than the coupe/hatch. And looking more closely at some interior pictures, I'd say that's probably correct.
CIP eh?
Old 10-25-2007, 12:00 PM   #9
MavericStephenc
yea, jeff and andrew are awesome. never dealt with matt, but the service is quick and their customer support is awesome
Old 10-25-2007, 12:14 PM   #10
projectRDM
projectRDM's Avatar
That's correct. The convertible Apillar trim doesn't bow out to clear the power seatbelt mechanism, since it doesn't exist. It's basically the same pillar as a UK/JDM piece, but cut off short at the top. The contour is completely different. You may find an S14 pod would work better, or maybe find someone who has one to test fit at least.
FORMERLY R240NA
Old 10-25-2007, 12:39 PM   #11
SHIFT_*grind*
Ahhhh, yeah, the auto seatbelt, I don't know why I didn't think of that as being different
