Old 10-06-2007, 01:15 PM   #1
RHS13KNetics
RHS13KNetics's Avatar
RHS13KNetics has made poor choicesRHS13KNetics has made poor choicesRHS13KNetics has made poor choicesRHS13KNetics has made poor choicesRHS13KNetics has made poor choicesRHS13KNetics has made poor choices
KA Engine Stutter
i have a 1990 240sx, was driving around yesterday after putting some lucas additive in it for the first time, i went into 4th gear and my shift knob started shaking like crazy, i came to a stop and when my engine is idling it stutters like put put put put put put. whereas b4 it was a constant purr. whats wrong?
Signature too large.
RHS13KNetics is offline   Reply With Quote
Old 10-09-2007, 11:28 AM   #2
RHS13KNetics
okayyyy well since no one cared to help me out. i am going to in turn help ones out who have the same problem. theres a good chance that if ur engine is stuttering then you are missing. hopefully its not a BHG. use process of elimination.
1 squirt water on the vacuum connections then rev the engine to look for bubbles.
2 take out spark plugs one at a time untill the engine sounds the same while pulling one out. check THAT spark plug for damages.
3 if its not the spark plug then check the fuel injection connectors. apparently 240sx came with crappy ones and they pop loose really easy. find a way to secure it back into place or get a new one
Thx forums...
Old 10-09-2007, 12:06 PM   #3
Sleepur
Sleepur is an unknown quantity at this point
I been havin the same problem man :/ its really freakin annoying.
Sleepur is offline   Reply With Quote
Old 10-10-2007, 08:33 PM   #4
s13rookie
s13rookie's Avatar
s13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant future
Send a message via AIM to s13rookie
RHS13- which one of those solved your problem?
Ive also seen people spray water onto their spark plug wires at night. If you see sparks, they need to be replaced. Silly domestic guys.
Did you check your fuel filter?
Ive spent most of my money on cars and women...the rest i wasted
s13rookie is offline   Reply With Quote
Old 11-03-2007, 10:49 AM   #5
RHS13KNetics
for me it was the fuel injector connectors. it turns out that the ones that the OEM 240 ones are crappy and get knocked loose after a while -_-
Old 11-03-2007, 05:33 PM   #6
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
gj on actually trying, and you've succeeded =]
Dave
RB25 280z GT30/76R 441hp/381tq 11.9@125
Z U L8R is offline   Reply With Quote
Old 11-03-2007, 06:57 PM   #7
mothon
mothon's Avatar
mothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond repute
Next time just pull the spark plug wire instead of taking out the plug its a lot quicker way to find out if that cylinder is firing.
mothon is offline   Reply With Quote
Old 11-06-2007, 02:55 PM   #8
69datsun510
69datsun510's Avatar
69datsun510 is making a name for him/her self69datsun510 is making a name for him/her self69datsun510 is making a name for him/her self
Originally Posted by RHS13KNetics View Post
okayyyy well since no one cared to help me out. i am going to in turn help ones out who have the same problem. theres a good chance that if your engine is stuttering then you are missing. hopefully its not a BHG. use process of elimination.
Thx forums...
Ever heard of the expression " suck baby, blow is only an expression"
A vacuum would only suck, and would not be able to produce bubbles. Sorry for being a smart ass, you at least tried to help the guy out. Search how to check for vacuum leaks. Some people use carb cleaner to spray around the engine compartment. If the idle goes up you have a leak. BE CAREFUL not to heat up the engine to much or get the carb spray near the exhaust manifold. PUFF no hair!!
To locate the misfire can be a hair ripping task. If you haven't done a tune up lately, start there. Get a new cap and rotor, spark plugs, fuel filter, and check for vacuum leaks.
Then if not fixed, pull each plug wire and see if motor idle changes. If no change on a cylinder, you have a bad wire or injector on that cylinder, pull the connector on the injector to check injector. Replace if bad. If it seems to still be missing go with a fuel pressure regulator then the O2 sensor. You should be getting a check engine code for the O2 sensor. You should check the throttle positioning sensor located on the throttle body. Search how to check TPS.
Well, that should get most of the common misfire problems, but there are more. Hence, why i said a hair ripping task!
Hope I helped you out and good luck
93 Coupe, 1969 510 2 Dr
69datsun510 is offline   Reply With Quote
