Old 09-22-2002, 03:04 PM   #1
nizmo s14
nizmo s14's Avatar
nizmo s14 is an unknown quantity at this point
Which one would be beter for drifting in your opinion?
-Serge
nizmo s14 is offline   Reply With Quote
Old 09-22-2002, 03:43 PM   #2
Apparition
Apparition's Avatar
Apparition is an unknown quantity at this point
Send a message via Yahoo to Apparition
As a relative newbie, how does the tall end gear have anything to do at all with drifting?
1990 240sx coupe *sold*
Apparition is offline   Reply With Quote
Old 09-22-2002, 03:48 PM   #3
adey
adey's Avatar
adey is an unknown quantity at this point
the tall end should have nothing to do with drifting, it would only really be useful on the highway (better gas mileage).
It's also been said (and I believe it) that the 6spd tranny (i assume we're talking about the silvia s13/14/15 5 speeds and the S15 spec-R's 6 spd trannies) from the S15 is slightly weaker than the 5-spds because there's another gear in the same sized tranny, and in order to fit another gear in there they had to make the other gears smaller.
from what I hear, "drifters" actually change the 6spd out of the spec-R in favor of the 5-spd, because it can take more abuse.
Instagram: @SX180HKG
adey is offline   Reply With Quote
Old 09-22-2002, 03:54 PM   #4
DSC
New Title
DSC is an unknown quantity at this point
1337 Dr1ft3r y0!
5spd would be better I guess. Assumeing the 2 trannys are the same size, the one with more gears would have to make the gears smaller to fit...so the 6spd would be weaker than the 5spd.
Edit: wow, way late one that one...what i get for hitting reply and walking away, then typing when i came back.
DSC is offline   Reply With Quote
Old 09-22-2002, 07:09 PM   #5
AKADriver
AKADriver's Avatar
More gears in the same space is the complaint about the 6 speed, but not in terms of strength.
The S15 6 speed is a close ratio box... meaning its 6th gear is not much taller than the 5 speed's 5th.  More gears in the same amount of space.  Driving my stock KA I never find the revs dropping too much on an upshift... it's never hard to keep the car in the powerband.  I don't need closer ratios.  An SR with the stock turbo shouldn't need them either, and reviews of the S15 seem to support this.
Now a high winding NA engine or an engine with a big turbo that spools slowly might need those ratios...  Which is exactly why Autech used the 6-speed in their version of the S15 (200hp NA SR20DE).
If you have to ask "which is better for drifting" then there's clearly a lot about the subjects of both gearing and drifting you have left to learn.  The answer is highly dependent on particular car/engine combinations and your own personal driving style.
Old 09-23-2002, 09:07 PM   #6
nizmo s14
nizmo s14's Avatar
TNX. I got my answer here.
-Serge
