Old 12-13-2007, 07:36 PM   #1
devonkyle77
devonkyle77's Avatar
devonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfection
Send a message via AIM to devonkyle77
s14 head bolt torque specs, for both KA and SR?
if someone could please provide me with head bolt torque specs for both s14 ka and s14 sr i would appreciate it. i do not have FSMS on my new pc yet, sorry!
thanks in advance
-devon
WTB-NARDI wheel & NRG 2.8 QR
devonkyle77 is offline   Reply With Quote
Old 12-13-2007, 07:59 PM   #2
MomentumGT
MomentumGT's Avatar
MomentumGT is a splendid one to beholdMomentumGT is a splendid one to beholdMomentumGT is a splendid one to beholdMomentumGT is a splendid one to beholdMomentumGT is a splendid one to beholdMomentumGT is a splendid one to beholdMomentumGT is a splendid one to beholdMomentumGT is a splendid one to beholdMomentumGT is a splendid one to beholdMomentumGT is a splendid one to beholdMomentumGT is a splendid one to behold
SR with ARP's at 70 with molly lube, if using regular motor oil torque it to 80.
-Jon
momentumgt.com - "building blocks of speed"
MomentumGT is offline   Reply With Quote
Old 12-13-2007, 08:02 PM   #3
statik
statik's Avatar
statik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond repute
Send a message via AIM to statik Send a message via MSN to statik
S14 SR (page 63):
http://static.carvolution.org/files/S14_SR20DET_FSM.pdf
S14 KA (page 19):
http://static.carvolution.org/files/...X%20FSM/EM.PDF
97 240sx esaarr | Current Status: SOLD
statik is offline   Reply With Quote
Old 12-13-2007, 08:27 PM   #4
devonkyle77
according to the fsm's, it looks like both (sr and ka) are to be torqued at no more than 60foot/lbs. am i reading this wrong? i appreciate your help thus far guys!
Old 12-13-2007, 08:32 PM   #5
statik
statik's Avatar
the KA uses slightly less i believe but both go something like:
tighten to 30
tighten to 60
loosen
tighten to 30
tighten to 60 *(thanks russ)
DONE
check those pages for the exact numbers but those should be close
Old 12-13-2007, 09:39 PM   #6
pwhitersxs
pwhitersxs will become famous soon enoughpwhitersxs will become famous soon enoughpwhitersxs will become famous soon enoughpwhitersxs will become famous soon enough
Send a message via AIM to pwhitersxs
With my headgasket and arp headstuds, I torqued to 80 ft lbs on my SR. Many others torque to that value as well. I would not go less than 70 ft lbs for an SR.
s13 sr20det
pwhitersxs is offline   Reply With Quote
Old 12-13-2007, 09:51 PM   #7
projectRDM
projectRDM's Avatar
tighten to 30
tighten to 60
loosen
tighten to 30
DONE
NO! unless you want a blown head gasket.
29ft-lbs
59ft-lbs
loosen
29ft-lbs
59ft-lbs
The first two steps stretch the bolt to spec.
FORMERLY R240NA
Old 12-13-2007, 10:21 PM   #8
devonkyle77
we are talking a new oem head gasket, new head studs on an sr.
just to be clear. like i said in a previous post, it looks like 60 ft lbs is what they want. you guys that are saying 70-80, or i will blow headgaskets, what is your reasoning?
Old 12-14-2007, 06:34 AM   #9
statik
statik's Avatar
29ft-lbs
59ft-lbs
loosen
29ft-lbs
59ft-lbs
My bad, on the next page in the sr fsm after tightening to 30 it calls for turning all the bolts 90* with an angle wrench and then turning them all again another 90*, and looking at the "elastic" image next to the studs it looks like its supposed to be just slightly more than 60 in the end. With new studs you might want to do the last part in 2 steps as the fsm calls for.
Old 12-14-2007, 07:00 AM   #10
pwhitersxs
Where is Mr. Shadows. He always says how he uses the oem headbolts.
I even think the stock headbolts are greater than 60 ft lbs. I don't feel like looking it up right now, but I would torque them to atleast 70 ft lbs, or better yet, follow the fsm. The fsm is the best way to do it right.
The reason you want more torque is so your headgasket does not leak. I fear putting just 60 ft lbs will cause a slow leak and then you will have to replace it sooner than later.
s13 sr20det
Old 12-14-2007, 05:57 PM   #11
tt99ol
tt99ol's Avatar
tt99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond repute
Send a message via AIM to tt99ol
if using arp studs you also have to torque them 5 times before final torque while using the moly lube that they provide
tt99ol is offline   Reply With Quote
