Old 02-04-2008, 08:11 PM   #1
louisdaboois
louisdaboois's Avatar
Trader Rating: (28)
louisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfection
Feedback Score: 28 reviews
Got coils. Screw HICAS. Need Toe?
hey guys, did a search of hicas toe arms vs reg. toe arms, got an answer, but just want a bigger consensus (sp?). Recently got some coilovers for the s13 and a regular old 5 lug conversion. It's plainly obvious that i cannot use standard, aftermarket rear toe arms on a hicas model 240. They look like messed up tie rods. If I'm not mistaken, they should have enough adjustment after lowering the car, correct? Thanks for the answers in advance!
louisdaboois is offline   Reply With Quote
Old 02-04-2008, 08:12 PM   #2
zsimp
zsimp will become famous soon enoughzsimp will become famous soon enoughzsimp will become famous soon enough
SPL makes adjustable toe rods for HICAS S13's
they also eliminate HICAS, so its a 2 for one deal.
zsimp is offline   Reply With Quote
Old 02-04-2008, 08:14 PM   #3
LongGrain
LongGrain's Avatar
^^^^ whoops, forgot to sign zack off. that was me.
LongGrain is offline   Reply With Quote
Old 02-04-2008, 08:18 PM   #4
louisdaboois
Trader Rating: (28)
o yeah, i was aware that they made the hicas eliminating adj. toe arms, but im a regular, run of the mill, 240 owner... im a cheap ass. The HICAS doesn't work anyway, the p/s lines are blocked off, so I'm not worried about that feature... I'm just wondering if I would NEED to get them to be able to adjust toe in the back and save some tires or if the stock ones will have enough adjustment. thanks for the heads up though!
