Old 01-27-2008, 09:14 PM   #1
rob3725
rob3725's Avatar
rob3725 is a well-known jackass
SR Weird Power Loss
Runnin redtop in my s13 umm...walbro 255lph,stock injectors,blitz ecu, stock maf, z32 fuel filter. Car builds and holds bout 7-8 lbs. steady no boost leaks it just doesnt want to go from all i can figure is a must not be getting enough fuel pending checkin the pressure once i get the tools already decided to go ahead and get a nismo fpr thinkin that mine may not be working properly but if anybody knows anywhere else this problem could be im stuck if its not my fpr. INJECTORS NOT LEAKING O RINGS ARE FINE. NEW FUEL FILTER. PULLED VALVE COVER AND SET TIMING MANUALLY DEAD ON
rob3725 is offline   Reply With Quote
Old 02-04-2008, 02:22 AM   #2
rob3725
rob3725's Avatar
OK intalled fpr big improvement but still not there gonna check for boost leaks not sure what will happen still lookin for some info if neone knows nething it'd be greatly appreciatted...
Old 02-04-2008, 02:37 AM   #3
sd8ted
sd8ted is an unknown quantity at this point
u have it set higher but it wont boost past 8psi? if so then maybe u need a new wg actuator
sd8ted is offline   Reply With Quote
Old 02-04-2008, 02:54 AM   #4
rob3725
rob3725's Avatar
no im running stock boost at the time it just doesnt seem to wanna go...feels pretty good when u first start to roll into it but i mean at 75% to full throttle or so it just falls flat on its face doesnt wanna go fast at all nowhere near what it should be doing at least
Old 02-04-2008, 03:22 AM   #5
eulalia
eulalia's Avatar
eulalia is close to perfectioneulalia is close to perfectioneulalia is close to perfectioneulalia is close to perfectioneulalia is close to perfectioneulalia is close to perfectioneulalia is close to perfectioneulalia is close to perfectioneulalia is close to perfectioneulalia is close to perfectioneulalia is close to perfection
Send a message via AIM to eulalia
check your timing
mine felt exactly the same and my timing was wayyy offf
eulalia is offline   Reply With Quote
Old 02-04-2008, 06:20 AM   #6
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
yeah check for boost leaks, and timing
Slip Gypsies Blog
not sure if you realize this
Old 02-04-2008, 01:34 PM   #7
boofa
boofa is on the path to ruinboofa is on the path to ruin
timing.
i thought my timing was DEAD ON too... but the 3rd time i did it... it was fine.. hahahahahaa... then again - maybe you're better at it than me?... but i would do it again just to make sure.
boofa is offline   Reply With Quote
Old 02-05-2008, 01:48 PM   #8
rob3725
rob3725's Avatar
lol ill try it again 12th times the charm lol may restab my cas too...checking for boost leaks today too
Old 02-06-2008, 06:40 PM   #9
rob3725
rob3725's Avatar
still havent got to the timing yet there arent any boost leaks but i changed the fuel filter and some nice RUSTYBROWN fuel came out of it...the tank is nasty...this could very well be the problem gonna try and locate another cleaner tank and change the sock on my pump NO CLUE WHERE TO FIND A NEW SOCK FOR THE WALBRO IF ANY BODY KNOWS IT'D BE APPRECIATED. so changed the filter took it for a drive...still no power seems to have a miss now too
