Old 10-15-2002, 11:32 PM   #1
luke91
luke91 is an unknown quantity at this point
Are there any larger diameter MAFS's out there that could be used on an S13 SR20 without any major modification (ECU reprogramming, S-AFC, etc...)?
Thanks
--luke
'91 fastback.  '97 S13 blktop SR20DET.  Cstm Frnt Mnt IC w/ cstm 2 1/2" piping.  stnls stl fltr.  3" cstm DP & exhst w/N1 muff.  Walbro FP.  ACT 6 pck cltch.  Go Fast Bits crnk plly.  Ground Control coils.  KYB AGX shks.  12.98@106 w/g-tech pro.  17psi.  All work and fabrication done by ME
luke91 is offline   Reply With Quote
Old 10-16-2002, 08:42 AM   #2
uiuc240
uiuc240's Avatar
uiuc240 is an unknown quantity at this point
Send a message via AIM to uiuc240
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (luke91 @ Oct. 16 2002,12:32)</td></tr><tr><td id="QUOTE">Are there any larger diameter MAFS's out there that could be used on an S13 SR20 without any major modification (ECU reprogramming, S-AFC, etc...)?
Thanks
--luke</td></tr></table><span id='postcolor'>
No.
With the Cobra, Z32, Q45, J30, etc. MAFS, you need to "trick" the ECU at the very least.
Something to consider: &nbsp;The flow restriction of the stock MAFS (what I'm assuming you're worried about) is not that bad. &nbsp;It's about a 2" hole and it only lasts for about an inch. &nbsp;After that, the piping is much bigger. &nbsp;This will have almost zero effect on your rwhp. &nbsp;The main reason for changing the MAFS is to accomodate more fuel and more range (stock MAFS can't read past the flow of air needed for about 275 rwhp).
Eric
Eric
2002 Mazda Protege5
1989 S13 w/SR20DET (sold)
uiuc240 is offline   Reply With Quote
Old 10-18-2002, 12:01 PM   #3
luke91
I'll be upgrading the turbo, soon. &nbsp;I had planned on using the JWT fuel upgrade program, but it's expensive. &nbsp;
I should be making around 320-350rwhp when it's done, so I figure I'll need 550cc injectors, and a MAFS. &nbsp;I already have a pump. &nbsp;
Is there a cheaper, easier way to do the necessary fuel upgrades that I will be needing? &nbsp;
thanks
--luke
'91 fastback. &nbsp;'97 S13 blktop SR20DET. &nbsp;Cstm Frnt Mnt IC w/ cstm 2 1/2&quot; piping. &nbsp;stnls stl fltr. &nbsp;3&quot; cstm DP &amp; exhst w/N1 muff. &nbsp;Walbro FP. &nbsp;ACT 6 pck cltch. &nbsp;Go Fast Bits crnk plly. &nbsp;Ground Control coils. &nbsp;KYB AGX shks. &nbsp;12.98@106 w/g-tech pro. &nbsp;17psi. &nbsp;All work and fabrication done by ME
Old 10-18-2002, 11:13 PM   #4
cnichols
cnichols's Avatar
cnichols is an unknown quantity at this point
Don't, I repeat, DO NOT look for a cheap way out when it comes to tuning...GET RID OF THE MASS AIR...it is NOT a good match for turbocharging. &nbsp;Save your money until you can afford some type of stand-alone ignition and fuel management system. &nbsp;To HE!! with JWT and their stupid reprogrammed ECU...why would you not want the ability to change all your settings by yourself instead of paying those slow ba$tards to redo it everytime you change something. &nbsp;In the end, you would proabably spend more.
11.0 @ 131 | LS1 | T56 Magnum
cnichols is offline   Reply With Quote
