Old 02-27-2008, 02:28 PM   #1
boogerlovers
boogerlovers's Avatar
boogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond repute
Ever done this to a cam...???
alright so last week i found out that i had my retop timing set 180 degrees off ...so i go to fix my timing yesterday and as i pull the cam bearings off i realize that my cam is in two pieces...:hammer:. Anywho i buy a cam from VUTONY (thanx for saving my ass) and i set the timing to what it should be and everthing is cherry right? of course not...i crank and i get nothing...im thinking im not getting fuel, anywho after i run out of things to check, my friend and i decide to do a leakdown test and i have 100% leakage on all four cylinders. i can hear air coming from the exhaust but not from the head or the throttle body, this means its the exhaust valves right??? and not the piston rings right??? eh just thought id share my stupid mistakes....sorry if this doesnt go in tech...if you have any ideas of other things it could be besides the valves please chime in...
boogerlovers is offline   Reply With Quote
Old 02-27-2008, 02:41 PM   #2
DunG HAB SP
DunG HAB SP's Avatar
DunG HAB SP is an unknown quantity at this point
wow not the first time i saw that one. i believe you might still be off of timing perform a leak down test and see what happens maybe valves aren't bent. and how are the journals when you took the cam off were they scored?
DunG HAB SP is offline   Reply With Quote
Old 02-27-2008, 04:13 PM   #3
Big Bronze Rim
Big Bronze Rim's Avatar
Big Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the rough
Did you crank the engine with the broken cam? My guess is bent valves if you did especially since that was the exhaust cam and the sound is coming from the exhaust.
"Genius may have its limitations,
but stupidity is not similarly handicapped."
Big Bronze Rim is offline   Reply With Quote
Old 02-27-2008, 04:46 PM   #4
boogerlovers
yeah i did, with out knowing of course...but yeah im thinking its the valves too, im actually waiting for a lift/hoist right now to unhook my exhaust so i can pull the head...
Old 02-27-2008, 07:46 PM   #5
Def
Did you follow the torque pattern for the cam bolts in the FSM?
Old 02-27-2008, 10:03 PM   #6
Gjohnson7
Gjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura about
Wow! And I thought my timing issue was bad. The long block I purchased had the cams off as well, but only about quarter turn in opposite directions. I did a compression check too and had 3 great cylinders and 1 bad one that was leaking through the intake. Pulled the head and all the valves and nothing is bent. I still can't figure out why it was leaking.
LSX Kouki Project, swap completed in Dec 09
Gjohnson7 is offline   Reply With Quote
Old 02-27-2008, 10:25 PM   #7
slider2828
slider2828's Avatar
It has been explained. Didn't follow directions, the CAM got pwned and the valve stuck in the open position. You cranked it, the piston slapped the valve and bent the valve. The valve due to deformaty will not recede back into the head fully hence compressure issues. Also you never know i you have cracked the piston as well since you slapped it that hard or at least nicked the crap out of the surface. Standard engine issues.....
Hench also friction on valve seals, the seals are gone now probably. Timing was off and you might have bent all 4 valves. Doesn't know, but what you did is basically what causes engines to blow. Not just a booboo, its full engine pwnage. Sorry full tear down on your way....
Turn and Burn!
Old 02-27-2008, 10:32 PM   #8
johngriff
johngriff's Avatar
No no. I would just re-do the valves and head gasket. Pistons are fine. The valves are not that strong at all.
And yeah, follow the Tightening patern and loosening pattern in the fsm/any sentra repair manual.. even a honda repair manual its the same.
[email protected]
Old 02-27-2008, 11:06 PM   #9
boogerlovers
yeah turns out none of the valves were bent...and the cam was snapped due to improper torque patterns...the pistons did not have a scratch on them...but i found a little piece of the cam embedded in the cam journal...i fail haha but hey its a learning process right...? it comes with doing your own shit, i will say this though i wouldnt trade this experience for anything, cuz now i know to quadruple check everything lol, yeah thanx for helpin out and not flaming me guys...
Old 02-27-2008, 11:12 PM   #10
boogerlovers
O yeah turns out the leaking was from the valves not seating correctly, not cuz they were bent but because they were not cut properly... anywho problem will be fixed tommorow when i cut and lap the valves myself...
Old 02-27-2008, 11:54 PM   #11
slider2828
slider2828's Avatar
Replace the valve seals if you have it all out... Might as well if possibl...
Turn and Burn!
