![]() Join Date: Sep 2007
Pinstripe removal?!
How can I safely remove a pinstripe that was handpainted on over the clear coat without damaging the clear underneath it?
![]() Join Date: Jan 2004
um...you'd still need to buff the clear if you manage remove the pinstipe, so i guess you could try to wetsand VERY CAREFULLY
or just flatblack the shit out of it and run an exhaust through your hood madmax style since we need to start jocking boso's nuts so import tuner will feature it |
![]() Join Date: Mar 2007
Trader Rating: (31)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 31 reviews
Yep..Eraser Wheel Is the bomb.It'll do it.
Mostly made for air tools but you can put it on a Drill and use it. Carquest has them...if you have those up there.
z-tERty-2 |
![]() Join Date: Jan 2007
Me and my buddy just did his GMC sierra. We wet sanded with 2K grit then buffed with a orbital, then used a polish on the orbital and it came out pretty good. Ill try and get pics.
91 coupe W/RB25-00 S2000-Daily-05 F-150-Daily |
#6 | |
what you need to do is go to the arts and crafts store, and buy all their glitter and glue. that's step one step two, get some extended wheel studs and mount your rims backwards so they stick out like five feet step three add more pinstripes
Laquer Thinner.
Painted on pinstripes are 99% of the time enamel. The laquer thinner will eat away at the enamel before causing damage to the clear-coat. If the pinstripe is already fading away from age, then a safer trick is to use WD-40 and alot of effort, but definitley less risky. There is always a danger, so definitley try rubbing some on the paint in your door-jam or under your trunk-lid. Goodluck. ........and yes, Ive used both methods plenty of times. If Ive never actually done it, then I dont speak on it. I dont post info that I read in some trendy mag or possibly passed on through the web by a none experienced builder who is able to type like he knows what hes talking about.
What the hell is "BALLER" or "GANGSTER" status, about a 240sx? |
![]() Join Date: Dec 2002
No. No one seemed to read that yours is painted on. An eraser wheel will not remove paint. Your best option is to wetsand carefully, then buff it again once it's off.
#12 | |
Funny story we had a dude who bought a black M45 and wanted it removed, the jackasses used everything they could think of in the detail shop, i mean everything, clay bar, wax, rubbing compound, etc. they fucked it all up and had to pay a ton to get it fixed.... hahaha put some bitches out of a job! sad but true.
![]() Last edited by INeedNewTires; 04-16-2008 at 09:53 AM.. |
#13 | |
It will eliminate the need for buffing since your not using anything that could scratch the finish.
#14 |
If someone has a VINYL pinstripe but doesn't have an ERASER wheel, I used an old valvestem. Stick the threaded part of the valvestem in your drill.
Honestly, I've never used an actual eraser wheel so I don't have anything to compare to, but the old valve stem removed the old adhesive from the brittle pinstripe. Valvestem, free, free, free. Get a handful of them next time you go get tires done.
#18 |
Dont forget that if the car's paint is old and/or dark it will probably be faded a bit, so when you remove the pinstripe the paint under it will be a bit fresher so it may still look like theres a ghost stripe............ hahaha may be cool but i doubt it, i hate pin stripes myself!
good luck removing it, take your time, use plenty of solvent, and you should be fine.
#19 |
I used nail polish remover. Took some elbow grease but works great and didn't do squat to the paint of the car. I tried a laquer thinner but the spot i test the clear came right off. Thankfully I tested on a spare fender i had.
