Old 11-14-2002, 10:50 PM   #1
YellwMonky
YellwMonky's Avatar
YellwMonky is an unknown quantity at this point
Well, I've found a vlsd from a japanese 96 180sx. I was just if this is okay to swap out with the open differential on my 1992 240sx SE. I'm guessing that the sr20det and the ka24de has different gear ratios. Would this have any effect when swapping out my old differential with this new one?
s13 92 White 240sx SE Coupe
YellwMonky is offline   Reply With Quote
Old 11-15-2002, 04:50 PM   #2
YellwMonky
YellwMonky's Avatar
nooooooooooooooooobody?
Old 11-15-2002, 08:23 PM   #3
mbmbmb23
Zilvia Contributor
mbmbmb23's Avatar
mbmbmb23 is on the path to ruinmbmbmb23 is on the path to ruin
It should work as long as you get the output shafts from that same car.  Make sure they have the same bolt pattern you have (a 3 star with 2 bolts holes on each star-point).
-m
400x200
mbmbmb23 is offline   Reply With Quote
Old 11-15-2002, 08:35 PM   #4
AKADriver
AKADriver's Avatar
SR20DET 5-speed (S13 and S14), and KA (all models) have the same 4.083:1 ratio.
The diff should bolt in unless, as mbmbmb23 noted, the output shafts are different.  if they are, either have your stock output shafts machined to fit, or buy new VLSD output shafts.
Old 11-16-2002, 02:38 AM   #5
YellwMonky
YellwMonky's Avatar
what they tell me is that it does not come with the axles, but it's 6 hole flanges so it'll bolt right up to my stock axles...Is this correct?
Old 11-16-2002, 03:05 AM   #6
Kid Zelda
Kid Zelda is an unknown quantity at this point
Send a message via AIM to Kid Zelda
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (YellwMonky @ Nov. 15 2002,04:38)</td></tr><tr><td id="QUOTE">what they tell me is that it does not come with the axles, but it's 6 hole flanges so it'll bolt right up to my stock axles...Is this correct?</td></tr></table><span id='postcolor'>
C o r r e c t &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sly.gif" border="0" valign="absmiddle" alt=':sly:'>
Kid Zelda is offline   Reply With Quote
