Hey guys and gals...I've started planning my chassis wiring for my 1992 S13 coupe. I will be wiring most of the circuits to toggle switches. So far, the only circuit I've found that I cannot (easily) wire on a toggle is the wipers/washer...which is ok, I can deal with multiple speeds. I have decided to go with a one-off (read: simplified) version of the factory wiring lay-out...what concerns me is the Time Control Unit. Below is the wiring diagram I made (copied from the FSM), since the only circuit controlled by the TCU I will be using is wipers/washer...will this set-up be sufficient to make them both work, or do I need to wire anything else into the TCU?
Any help or info is appreciated...Thanks in advance!
