Old 05-30-2008, 09:47 PM   #1
Omarius Maximus
Omarius Maximus is a glorious beacon of lightOmarius Maximus is a glorious beacon of lightOmarius Maximus is a glorious beacon of lightOmarius Maximus is a glorious beacon of lightOmarius Maximus is a glorious beacon of lightOmarius Maximus is a glorious beacon of lightOmarius Maximus is a glorious beacon of lightOmarius Maximus is a glorious beacon of lightOmarius Maximus is a glorious beacon of lightOmarius Maximus is a glorious beacon of lightOmarius Maximus is a glorious beacon of light
Using a GT turbine housing on a T28, possible?
I'm basically building a frankenstein turbo, and I have a T28 center section. I have a GT28R turbine housing coming in the mail for me, and was wondering if they would "fit"?
I understand that the T25/T28 turbine housings are attached via 4 bolts, and the gt turbine housings use 6. I was thinking about machining custom plates, to combine the two.
The only thing I need to know is if the openings are the same?
Omarius Maximus is offline   Reply With Quote
Old 05-30-2008, 11:23 PM   #2
McRussellPants
wheel sizes are different.
no.
why.
McRussellPants is offline   Reply With Quote
Old 05-31-2008, 09:42 AM   #3
Omarius Maximus
The wheel diameter is the same, it's the "trim" that's different...
As to why...well...it's a long and stupid story not worth hearing.
Old 05-31-2008, 10:58 AM   #4
McRussellPants
trim is a function of wheel diamter.
it could work if the trim was smaller I geuss, but thats probably not the case, and having basically clipped T28 would be the worst turbo ever.
Old 05-31-2008, 11:12 AM   #5
Def
The GT housing with an NS111 turbine wheel will have a larger diameter than the 53mm wheel in a T28/GT2560R. It'll be like constantly having your wastegate cracked open a bit - i.e. it'd suck.
