Old 04-16-2008, 10:20 PM   #1
WagDatto
WagDatto's Avatar
WagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfection
Send a message via AIM to WagDatto
Car is dying on decel - around 3k rpm
I posted this in my build thread as well. I looked, but couldn't find an answer. Two nights ago, under deceleration, the 'Goon bogged down and died. Okay, no big deal, just a fluke? It happened a few times that night, I figured it was just the idle being adjusted a little wrong. Unfortunately, the next day (yesterday) it was the same story, as well as today...
With my car, I have the IACV blocked off, and I'm using the TPS (adjuster screw) to set my idle. I've had no issues before now. One thing I did find out is that the IACV came unplugged (shitty vacuum plug) and I thought that was the culprit. My thinking was that I was letting too much air in (through the TB and IACV) and it was causing me to run much too lean and die on decel toward idle. However, I sealed it using actual heater hose, and I still had the same issue.
1st, 2nd or 3rd gear, as soon as I decel to around 3k rpm (guesstimation, I don't have a tach) it starts to bog. Sometimes it will die, sometimes it will sputter and finally catch idle and be okay to go. KCNDizzle suggested MAF plug/wiring, as the MAF is the usual suspect for any problems around 3k rpm. I will check them tomorrow when it's light outside, and make sure everything is plugged in and secure, and there are no effed up wires.
Anybody have any other suggestions?
http://garagezoku.blogspot.com
WagDatto is offline   Reply With Quote
