Old 06-07-2008, 12:02 AM   #1
tekniq
tekniq will become famous soon enoughtekniq will become famous soon enoughtekniq will become famous soon enoughtekniq will become famous soon enoughtekniq will become famous soon enough
Send a message via AIM to tekniq
stance GR+ defect?
Hi everyone, i tried searching for this problem but to no prevail of a solution.
So this is my situation...about 4-5 months ago i purchased a set of stance GR+ and installed them into my car. Since then i haven't adjusted anything other then the dampening bolts located at the bottom of the front struts and top of the rear. Today i set out with the objective of being lower. I proceeded with adjusting the bottom sleeve of the rear passenger side strut and everything went smoothly. As i transitioned over to the driver side strut and was tightening the sleeve to lower the car the threads seized up. I completely took off the sleeve to see if there was anything in the way and there i noticed inside the sleeve about 5-10mm below where the threads ended there were bumps in the metal resembling bubbles. i tried sanding out the bubbles but after a few hours of effort i gave up after trying every 20 minutes to tighten the sleeve on past those bubbles. i was using 80 and 180 grit sandpaper. i also thought that using something to bore out the sleeve below the threads or somehow getting rid of the threads on the strut itself might work. but i didn't know if that was a safe thing to do. The threads seem to be in good condition and i have not damaged them in any way.
Could this be a defect that stance would be willing to take care of? or will i be able to fix it myself...I would prefer to do it myself, if possible, because i want to get it taken care of and be lower asap! i haven't checked with stance yet because i finished pretty late so no one would be there to answer at this time.
tekniq is offline   Reply With Quote
Old 06-07-2008, 12:04 AM   #2
HS13KLS
HS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant future
pictures will help.. a lot
HS13KLS is offline   Reply With Quote
Old 06-07-2008, 12:10 AM   #3
tekniq
i had already reinstalled them to get my car back on the ground and to return my friends tools but ill try to get some pictures up as soon as i get the chance. hopefully tomorrow.
Old 06-07-2008, 12:18 AM   #4
ryguy
ryguy's Avatar
ryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfection
I think rust has been a problem on Stance coilovers that see winter. I used a wire brush on mine and I was able to get the car lower.
ryguy is offline   Reply With Quote
Old 06-07-2008, 09:28 AM   #5
aznpoopy
aznpoopy's Avatar
bubbling is probably rust forming under the coating and is pretty typical of any coilover.
