Old 06-03-2008, 01:05 AM   #1
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
silvia wide fenders & front end parts, canards, coupe trunk lock, SMIC, & RHD clip
All prices are picked up unless otherwise stated. If you wanna meet me halfway you'd better be willing to pay for my gas because I'm selling this shit for cheap.
B-Magic s-13 front wide fenders (20mm I believe)
They are used and have on large crack on one fender and one small crack on the other. The vents have been trimmed larger to clear my ultra racing fender braces. I really don't want to ship these, but if you make it worth my while I will consider it.
SOLD, FINALLY!!!
S-13 silvia amber corner lamps
Sprayed amber,not OE. A couple small nicks and scratches but still look good. Tabs and one of the mounting brackets are broken, but have been repaired. The white residue around the edges in the pics is polishing compound not permanent defects.
$25 shipped in the 48
This image has been resized. Click this bar to view the full image. The original image is sized 1024x768 and weights 364KB.
This image has been resized. Click this bar to view the full image. The original image is sized 1024x768 and weights 401KB.
APR carbon fiber canards
One small scratch, other than that in perfect condition.
SOLD!
BNIB s-13 coupe trunk lock with key
As stated brand new and un-opened OE nissan coupe trunk lock cylinder with keys.
$30
RHD front clip
All the mechanical parts needed ofr a RHD conversion. Steering column, steering rack, RHD steering lines, brake booster, brake master, brake lines, brake & clutch pedals, clutch master, clutch line, hood release cable, hood latch, dash bar, and dash bar mounts. I have a RHD dash (but it is damaged), center console (slightly damaged), radio and shifter bezel, kick panels, glovebox, lower panel for driver's side, basically everything but the door panels and guage cluster bezel (same as US). I do not have any of the RHD wiring or HVAC parts and the inner tie rod ends were aftermarket and are being used on my car.
Make offers on the individual parts if you only need a couple
SOLD items
-center console
-gas pedal
PENDING items
-brake master cyl
-clutch pedal
-clutch line
CA18 SMIC set-up
COMPLETE SMIC set-up including the piping, intercooler, bumper duct, and fender liner. Would probably be perfect for a KAE turbo set-up as the CA throttlebody is in the same position as the KAE throttlebody as far as I can tell.
$50
S-13 silvia light brackets
A bit damaged but completely useable.
$25
Silvia bumper support and lower mounting bracket
Un-damaged silvia bumper support and the lower bracket strip.
SOLD!
RCI 5-point harnesses
A set of RCI 5-point harnesses set-up to bolt in to the rear seatbelt mounting locations. I had to use the eyelet style seatbelt mounts on my new belts so you're going to have to source your own.
no longer for sale
racepar1 is offline
Old 06-04-2008, 11:44 AM   #2
racepar1
racepar1's Avatar
bumpitty bump!
racepar1 is offline
Old 06-05-2008, 11:09 AM   #3
racepar1
racepar1's Avatar
Fenders sold, finally!!!
racepar1 is offline
Old 06-09-2008, 01:25 PM   #4
racepar1
racepar1's Avatar
All items OBO!
racepar1 is offline
Old 06-09-2008, 01:41 PM   #5
cinek10
cinek10's Avatar
cinek10 is an unknown quantity at this point
Send a message via AIM to cinek10
do you have the cluster for it?
cinek10 is offline
Old 06-09-2008, 06:34 PM   #6
racepar1
racepar1's Avatar
The cluster is being used in the car that the engine is going into, soooo no I don't.
racepar1 is offline
Old 06-09-2008, 06:37 PM   #7
DreamN
DreamN's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
Aaron I might have to take that bumper support off your hands. Mine is bent. Maybe after the event when I have the money though. Hopefully you still have it by then.
- Jimmy
Wanted:
TBD
For Sale:
TBD
DreamN is offline
Old 06-09-2008, 07:29 PM   #8
918DRFT
918DRFT's Avatar
918DRFT is a splendid one to behold918DRFT is a splendid one to behold918DRFT is a splendid one to behold918DRFT is a splendid one to behold918DRFT is a splendid one to behold918DRFT is a splendid one to behold918DRFT is a splendid one to behold918DRFT is a splendid one to behold918DRFT is a splendid one to behold918DRFT is a splendid one to behold918DRFT is a splendid one to behold
is tht the support off the conversion?
918DRFT is offline
Old 06-09-2008, 09:11 PM   #9
racepar1
racepar1's Avatar
It is the bumper support that came on the clip, I gotta get this shit outta my shop and my buddy, who I am doing the swap for, really has nowhere to put it.
racepar1 is offline
Old 06-09-2008, 09:18 PM   #10
ill_concepts
ill_concepts's Avatar
ill_concepts is close to perfectionill_concepts is close to perfectionill_concepts is close to perfectionill_concepts is close to perfectionill_concepts is close to perfectionill_concepts is close to perfectionill_concepts is close to perfectionill_concepts is close to perfectionill_concepts is close to perfectionill_concepts is close to perfectionill_concepts is close to perfection
Send a message via AIM to ill_concepts
I want the CA SMIC how far is reseda from palmdale?
ill_concepts is offline
Old 06-09-2008, 09:30 PM   #11
racepar1
racepar1's Avatar
^^^PMed msglngth
racepar1 is offline
Old 06-10-2008, 01:50 PM   #12
racepar1
racepar1's Avatar
Gas pedal from clip sold.
racepar1 is offline
Old 06-10-2008, 02:39 PM   #13
onehundredoctane
onehundredoctane's Avatar
onehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfection
pm'd you about BMC, need it if possible.
onehundredoctane is offline
Old 06-10-2008, 03:50 PM   #14
miravete
miravete's Avatar
Trader Rating: (44)
miravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant future
Feedback Score: 44 reviews
theres no wiring for the rhd clip? what part of socal you at exactly?
miravete is offline
Old 06-10-2008, 04:25 PM   #15
RPM MOTORSPORTS 2
RPM MOTORSPORTS 2's Avatar
RPM MOTORSPORTS 2 is a glorious beacon of lightRPM MOTORSPORTS 2 is a glorious beacon of lightRPM MOTORSPORTS 2 is a glorious beacon of lightRPM MOTORSPORTS 2 is a glorious beacon of lightRPM MOTORSPORTS 2 is a glorious beacon of lightRPM MOTORSPORTS 2 is a glorious beacon of lightRPM MOTORSPORTS 2 is a glorious beacon of lightRPM MOTORSPORTS 2 is a glorious beacon of lightRPM MOTORSPORTS 2 is a glorious beacon of lightRPM MOTORSPORTS 2 is a glorious beacon of lightRPM MOTORSPORTS 2 is a glorious beacon of light
Do you have any idea what the shipping cost would be to 33714 Saint Petersburg, Fl.?
Thanks
Roy
Sorry this is for the RHD clip
Last edited by RPM MOTORSPORTS 2; 06-10-2008 at 04:27 PM.. Reason: forgot to identify what I was looking for
RPM MOTORSPORTS 2 is offline
Old 06-10-2008, 04:56 PM   #16
racepar1
racepar1's Avatar
Nope I am going to use the RHD wiring in my car as it has less crap in it and it runs down the passenger's side of the car. I am in the san fernando valley, about 30 mins north of LA.
Thanks
Roy
Lemme check, but I'm sure it will be a lot.
racepar1 is offline
Old 06-10-2008, 08:52 PM   #17
excelS13
excelS13's Avatar
excelS13 is just really niceexcelS13 is just really niceexcelS13 is just really niceexcelS13 is just really niceexcelS13 is just really niceexcelS13 is just really niceexcelS13 is just really niceexcelS13 is just really nice
i think i pmed you
excelS13 is offline
Old 06-10-2008, 10:35 PM   #18
racepar1
racepar1's Avatar
Originally Posted by excelS13 View Post
i think i pmed you
No you didn't, so I'll PM you.
racepar1 is offline
Old 06-12-2008, 08:40 AM   #19
greenmonster80
greenmonster80 is making a name for him/her selfgreenmonster80 is making a name for him/her selfgreenmonster80 is making a name for him/her self
PM sent on the center console
greenmonster80 is offline
Old 06-12-2008, 09:13 AM   #20
91240sxgtr
91240sxgtr's Avatar
91240sxgtr has a spectacular aura about91240sxgtr has a spectacular aura about91240sxgtr has a spectacular aura about91240sxgtr has a spectacular aura about91240sxgtr has a spectacular aura about91240sxgtr has a spectacular aura about
Send a message via AIM to 91240sxgtr Send a message via Yahoo to 91240sxgtr
i need those to hardlines for the powersteering- the ones right behind the crossmember- i like 45min fro you - how much u want?
91240sxgtr is offline
Old 06-12-2008, 04:29 PM   #21
racepar1
racepar1's Avatar
PM's replied.
racepar1 is offline
Old 06-12-2008, 05:04 PM   #22
mrmephistopheles
mrmephistopheles's Avatar
excessive bumping.
Originally Posted by PHLIP
mrmephistopheles is offline
Old 06-12-2008, 07:14 PM   #23
racepar1
racepar1's Avatar
Mr meph you forgot to close it! LOL!
racepar1 is offline
Old 06-12-2008, 08:46 PM   #24
excelS13
excelS13's Avatar
interested in silvia light brackets and the silver corners. you said there damage but i can still use them? like how bad?
excelS13 is offline
Old 06-13-2008, 01:46 AM   #25
mrmephistopheles
I hate it when I do that!
Old 06-13-2008, 05:19 PM   #26
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
you did it again kev. LOL
New Video
Buy my mounts!
drift freaq is offline
Old 06-13-2008, 06:19 PM   #27
racepar1
racepar1's Avatar
Seriously man! Mr meph is slippin! LOL!
racepar1 is offline
