Old 06-18-2008, 09:05 PM   #1
silviaz
silviaz's Avatar
silviaz is making his/her stupidity well-knownsilviaz is making his/her stupidity well-knownsilviaz is making his/her stupidity well-knownsilviaz is making his/her stupidity well-knownsilviaz is making his/her stupidity well-known
lower timing chain ka24de
Hi guys! I have a little problem now. I have the redo my lower timing chain gasket on my ka24de. Do I need to remove the upper timing chain cover or not ? The engine is at the garage right now and they only did the upper timing chain. I know I have to redo my oil pan gasket too.... My engine is out of my car.
Right now I don't have my engine in front of me, but in the FSM they say on the 1rst line "1. Remove upper timing chain. (refer to upper timing chain in removal)
2. Remove the oil pan...
3. etc...
Do I really need to remove my timing chain AGAIN if I only want to change the damn gasket.....
I'm totally lost the FSM looks like to show me some things I don't have to do If i'm not planning to remove my timing chain since it's brand new right now...
silviaz is offline   Reply With Quote
Old 06-18-2008, 09:13 PM   #2
projectRDM
projectRDM's Avatar
There is no 'gasket', just RTV. If you're only redoing that, you don't have to pull anything else besides the oilpan. The covers can come off separately.
FORMERLY R240NA
Old 06-18-2008, 09:20 PM   #3
silviaz
silviaz's Avatar
It's fine for the oil pan. Are you sure if the lower timing chain cover come separately from the upper timing chain cover ? The garage is telling me they have to remove what they did if they want to do my lower gasket cover....
If not, I only have to remove my alternator and water pump and my pulleys to acces to my lower cover.
Old 06-18-2008, 09:23 PM   #4
projectRDM
projectRDM's Avatar
Originally Posted by silviaz View Post
It's fine for the oil pan. Do you know if the lower timing chain cover come separately from the upper timing chain cover ?
It's sure I have to remove my alternator and water pump and my pulleys....
Written directly above you: The covers can come off separately.
Water pump does not have to be removed, just pull the cover with it still attached. Neither does the alternator, just remove the top bracket.
FORMERLY R240NA
Old 06-18-2008, 09:25 PM   #5
silviaz
silviaz's Avatar
Thank you very much! I wanted to be sure because my english is not perfect. I guess if I only need to do that i'll do the job myself
+rep
