Old 06-22-2008, 09:50 AM   #1
Pblesh85
Pblesh85's Avatar
Trader Rating: (48)
Pblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of lightPblesh85 is a glorious beacon of light
Feedback Score: 48 reviews
Question HKS turbo timer issue
I have an old school hks turbo timer(the kind that looks like a profec b, the first one) and its not working right.
it has four settings:
1min
3min
5min
and a continuous setting
The issue is when I press any of the settings and the car is on and running. I turn it al the way off and it does what it should for about 5-10 sec then turns off.
When the ignition is on but the car is not running and I turn it off, the car stays on for as long as whatever setting its on... WTF ???
Is my turbo timer fried or just so old that I should just replace it or is it some easy fix im overlooking ?
Do you suffer from vaginal dryness...
Pblesh85 is offline   Reply With Quote
Old 06-22-2008, 10:02 AM   #2
g6civcx
g6civcx's Avatar
I don't know the wiring diagram, but generally the car has 2 wires that get power with the ignition switched to ON:
1) gets power at ACC and ON;
2) gets power at ON and ST.
Take a look at the car again. Get the engine running. Turn your radio on. Hit the setting and take the key out.
Does the engine die after 5-10 seconds but the radio stays on? It's supposed to do the opposite, i.e. kill all the accessories but keep the engine on.
If that's the case, you have your 2 wires backward.
If not report back and we'll see.
Old 06-22-2008, 10:16 AM   #3
Pblesh85
Pblesh85's Avatar
Trader Rating: (48)
No, it does what it should with the car running and when the radio and crap are just on(car not running). But when the car is running it does not keep it running as long as it should after the key is turned off.
Old 06-22-2008, 12:22 PM   #4
DataXUnknown
Trader Rating: (30)
DataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfection
Feedback Score: 30 reviews
My buddy told me thats what happened to his friends, and he ended up just getting a new TT and it worked fine. So your TT might be fried.
Just double check your wiring.
DataXUnknown is offline   Reply With Quote
Old 06-22-2008, 03:12 PM   #5
g6civcx
g6civcx's Avatar
We have a little problem with reading comprehension. Let's try this again.
What happens after this in terms of engine and radio?
Old 06-22-2008, 03:16 PM   #6
rightcoastimports
rightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond repute
man up buy a new TT.. i use a greddy one, works great. if you need a price pm me.
95 SR Zenki | @ e_form
daily - A34 Maxima | A36 Maxima
rightcoastimports is offline   Reply With Quote
Old 06-22-2008, 06:47 PM   #7
Pblesh85
Pblesh85's Avatar
Trader Rating: (48)
Ok, when everything is on(motor,radio,the works) and the timer is set. I turn the key off and the timer works fine, for 5-10 secs then turns off(like it would after the time runs out).
If I turn the key but do not start the engine, set the timer and then turn the key off. The timer works just fine. Just not when the engine turns on. Very seldom it will work when the engine is on(very seldom).
Old 06-22-2008, 06:56 PM   #8
ocn
ocn's Avatar
ocn is on a distinguished road
you might need to pull your ebrake up higher.. mine had the sam issue its the ebrake sensor.. just pull it high see if that works.
ocn is offline   Reply With Quote
Old 06-22-2008, 06:59 PM   #9
Pblesh85
Pblesh85's Avatar
Trader Rating: (48)
should it matter ? mine is auto(for a few more days, Auto sr. ha-ha)
Old 06-22-2008, 08:36 PM   #10
g6civcx
g6civcx's Avatar
Yes. The wire needs to see ground. Doesn't matter if it's auto or manual.
Old 06-22-2008, 08:47 PM   #11
Pblesh85
Pblesh85's Avatar
Trader Rating: (48)
Plus 1 to you.
Your awesome, im an idiot. You just fixed my prob.
I was not using my ebrake to park(since its auto).
Thank you.
Old 06-23-2008, 06:10 PM   #12
ocn
ocn's Avatar
no prob
