Old 06-24-2008, 10:46 AM   #1
Champz
Champz's Avatar
Champz is an unknown quantity at this point
High IDLE on ka24de
Im facing high idle on my 240sx 91, its idling around 1100-900
i tried adjusting the idle screw but it seems like it would not go lower then 1100-900, but it will go higher. all the vacuums are good no leaks
anyone help, will be much appreciated
thanks
champz
Tooo Sloooow 4 youuuu!
Champz is offline   Reply With Quote
Old 06-24-2008, 11:12 AM   #2
PBucch
PBucch's Avatar
PBucch is close to perfectionPBucch is close to perfectionPBucch is close to perfectionPBucch is close to perfectionPBucch is close to perfectionPBucch is close to perfectionPBucch is close to perfectionPBucch is close to perfectionPBucch is close to perfectionPBucch is close to perfectionPBucch is close to perfection
Im curious as well, my dohc swap is idling around 2500 lol
section ef&ec changed my life
PBucch is offline   Reply With Quote
Old 06-24-2008, 11:27 AM   #3
98s14inaz
98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection
Your throttle cable is too tight, loosen it.
-Retired
98s14inaz is offline   Reply With Quote
Old 06-24-2008, 12:29 PM   #4
Champz
Champz's Avatar
positive its not throttle cable
Old 06-24-2008, 12:45 PM   #5
titos14zenki
titos14zenki can only hope to improve
yep myn idles at 1500 for a minute then lowers to about 1100 if i try to adjust it any lower it wont rev right at all
titos14zenki is offline   Reply With Quote
Old 06-24-2008, 02:02 PM   #6
ms!3
if its not your iacv you probably have some sort of vacuum leak. 15y/o lines only stay together for so long.
ms!3 is offline   Reply With Quote
Old 06-24-2008, 02:06 PM   #7
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
http://www.zilvia.net/f/showthread.php?t=190745
Everyone was bugging me to write this and nobody posted in it after I wrote it.
