Old 07-13-2008, 02:30 PM   #1
kaaos
kaaos is making his/her stupidity well-knownkaaos is making his/her stupidity well-knownkaaos is making his/her stupidity well-knownkaaos is making his/her stupidity well-known
s14 auto to manual swap cuts off 2500 rpm
i blew my motor and threw a 5 speed in as well. now when i rev it it acts like its hitting a rev limiter or fuel cut off at 2500 rpm. wtf is wrong.
also i deleted every egr and emissions item i could including pcv. i welded the ports shut. so i dont think it has a leak.
kaaos is offline   Reply With Quote
Old 07-13-2008, 02:39 PM   #2
adrians_s13
adrians_s13's Avatar
Trader Rating: (29)
Feedback Score: 29 reviews
sounds like mafs man. Usually when theres something wrong with the mafs, it goes into a "safe mode" or something that usually won't let you rev past 3k or something. Check the wiring.
@adrianfromthecastle
Old 07-13-2008, 02:43 PM   #3
SexPanda
SexPanda's Avatar
SexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfection
Send a message via AIM to SexPanda Send a message via MSN to SexPanda
yeah that sounds like its in safe mode. Swing down to Oreilly's and have them put that shiznit on the code reader.
Easiest way to find the problem.
SexPanda is offline   Reply With Quote
Old 07-13-2008, 03:44 PM   #4
kaaos
k well i got a p1105 code map / barometric pressure switch solenoid valve do i need to fix this too?
p1441 ev/v bypass valve which i think is just emissions
p0105 absolute pressure sensor circuit wtf is this?
p1605 a/t comm line yay no more a/t
p0100 mass air or volume air flow circuit this is probally the culprit
and a few more evap system codes. should i be worried about any of the other codes. trying to troubleshoot the mass air system now
Old 07-13-2008, 08:18 PM   #5
jdm538
jdm538's Avatar
Trader Rating: (30)
jdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfection
Feedback Score: 30 reviews
yup thats a maf issue find a friend with a maf and diagnose.
jdm538 is offline   Reply With Quote
Old 07-13-2008, 08:19 PM   #6
Saviorsoul
Saviorsoul is making his/her stupidity well-knownSaviorsoul is making his/her stupidity well-knownSaviorsoul is making his/her stupidity well-knownSaviorsoul is making his/her stupidity well-known
MAFS. Find someone parting out there 240 and buy they're MAF, because a new one is EXPENSIVE
Saviorsoul is offline   Reply With Quote
Old 07-13-2008, 09:28 PM   #7
wiggafly808
wiggafly808's Avatar
wiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to all
+1 on mafs.. i had the same issue, but only intermittently.. picked up a used maf, fixed the problem.
wiggafly808 is offline   Reply With Quote
Old 07-13-2008, 09:32 PM   #8
Jonnyblaze
Jonnyblaze's Avatar
Jonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymore
+2 for maf.. happened to me.. replaced it.. badda bing badda boom
'91 Hatch - Work in Progress
Jonnyblaze is offline   Reply With Quote
