#1 | |
![]() hi, my name's adam, and i have idle irregularity issues.
i did a lot of searching, and although i have found a lot of info on iaa related problems, one big important piece of information remains unknown: where IS the IAA valve?! after reading the following, i want to try to establish another ground wire. Quote:
![]() Join Date: Oct 2002
The IAA valve assembly is located on the passenger side of the motor down
below and behind the intake manifold. It's about 8" from the firewall. According to the Nissan shop manual, to adjust the IAA valve, disconnect the throttle sensor harness connector with the motor shut off. Now with the engine idling in neutral, adjust the IAA for an idle speed of 650 RPM. With the motor shut off, reconnect the harness connector. Now with the motor idling, you should have an idle speed of 700 RPM. If you can't get the proper idle speed, the AAC valve may be defective as It's the one that receives signals from the ECU. The AAC bolts on to the IAA. Hope this helps. got this from faq's at 240sx.org |
![]() Join Date: Jan 2002
im pretty sure you will need to remove the intake manifold. I found that the easiest on mine because i didnt feel like removing all the other bullshet around it
240SXONE www.240SXMOTORING.com --- One Stop Shop for Your Nissan 240sx ![]() ![]() |
i took off the intake pipe and hosed down the throttle body with carb cleaner, and also sprayed a liberal amount down the hose leading to the IAA. cleared up all idle problems. i've only driven it about 15 or 20 miles since then, but it's been driving fine.... so, anyone with idle irregularity: a can of carb cleaner can go a long way.
