Old 10-04-2008, 10:49 AM   #1
lolatclint
lolatclint has much to be proud oflolatclint has much to be proud oflolatclint has much to be proud oflolatclint has much to be proud oflolatclint has much to be proud oflolatclint has much to be proud oflolatclint has much to be proud oflolatclint has much to be proud oflolatclint has much to be proud oflolatclint has much to be proud oflolatclint has much to be proud of
Send a message via AIM to lolatclint
Starting Problem
When I start my car it idles very low and dies out. It usually takes a second shot to get it goin and a little gas.
heres a vid
YouTube - start up
lolatclint is offline   Reply With Quote
Old 10-04-2008, 11:17 AM   #2
Sileighty_85
Sileighty_85's Avatar
check Timing and for vacuum leaks
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 10-04-2008, 05:15 PM   #3
lolatclint
alright ill check it out when i get home. oh and is there any more possibilities so i can look into it?
thanks
Old 10-04-2008, 05:25 PM   #4
smurfgcr
smurfgcr is making a name for him/her selfsmurfgcr is making a name for him/her self
what motor is this and did it start happening after you did anything special to the car?
smurfgcr is offline   Reply With Quote
Old 10-04-2008, 09:42 PM   #5
lolatclint
SOHC and no it worked fine and this has been goin on for the past 2 weeks
Old 10-04-2008, 10:32 PM   #6
jorge1190
jorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to all
mine did this...but it ended up being a blown headgasket..but check for vacuum leaks like he said
jorge1190 is offline   Reply With Quote
Old 10-04-2008, 10:42 PM   #7
smurfgcr
had the same problem on a SOHC, turned out motor was running on 3 cylinders. Check your spark and make sure you are getting fuel to all cylinders. could be many different issues all hitting at once but it sounds like an electric problem.
