Old 02-09-2003, 03:56 AM   #1
adey
adey's Avatar
adey is an unknown quantity at this point
Resurfacing flywheel
I will be getting a new clutch within the next month or so, and the question of flywheel resurfacing has come up a few times.
I'm confused as to whether or not I "need" to resurface my flywheel when putting in a new clutch. Is it a "must" as when changing brake pads, or is it optional?
How do you know when your flywheel can no longer be resurfaced? (too thin) or does it nearly 'never' get too thin?
Thanks!
Instagram: @SX180HKG
adey is offline   Reply With Quote
Old 02-09-2003, 05:50 AM   #2
HKrpS13
HKrpS13 is an unknown quantity at this point
Send a message via AIM to HKrpS13
I think it's the same as brake discs. Even though it feels smooth, you should always get your brake discs resurfaced when changing your brakepads.
HKrpS13 is offline   Reply With Quote
Old 02-09-2003, 11:00 AM   #3
tnord
tnord's Avatar
tnord is an unknown quantity at this point
you HAVE to do it..........can ruin your clutch if you don't, though i can't remember why so i may be wrong.
tnord is offline   Reply With Quote
Old 02-09-2003, 12:47 PM   #4
kandyflip445
kandyflip445's Avatar
You should be able to find the specs on the flywheel in a FSM. I think.... But, yeah, you have to surface your flywheel.
Old 02-09-2003, 01:05 PM   #5
silnv
silnv's Avatar
Trader Rating: (39)
silnv is an unknown quantity at this point
Feedback Score: 39 reviews
Send a message via AIM to silnv
I got mine resurfaced when I put my Spec in. It only cost me like 35.00 to get it done and about a half hour of time. So I would say its well worth it to get it done.
1997 Nissan 240sx
1991 Nissan 240sx hatch
silnv is offline   Reply With Quote
Old 02-09-2003, 01:41 PM   #6
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
telltale signs for flywheel resurfacing: blueing of the surface area or checking (yes it looks like checkerboards) slight grooves in the surface from worn out driven disc.
Ok , now if your clutch just starts slipping and you immediately pull it out and replace it you can get away with sanding your flywheel surface area and not have a problem.
The thing is most people drive the car for a number of miles still after the clutch starts to slip. Sometimes they drag race or race period and seriously burn up the driven disc surface. which heats the flywheel causeing what I said above , blueing or checking or even grooving.
AT this point resurfacing is a imperative! Don't do it and you will get clutch chatter and your clutch will wear out a lot sooner.
thats the low down on flywheel resurfacing
New Video
Buy my mounts!
Old 02-09-2003, 04:09 PM   #7
adey
adey's Avatar
Okay... sounds like I have my answer. Cool. Thanks for the help!
Old 02-09-2003, 08:50 PM   #8
aqwkmf
aqwkmf is an unknown quantity at this point
most clutch warentys(sp) require the flywheel to be resurfaced
aqwkmf is offline   Reply With Quote
