Old 12-21-2007, 09:21 PM   #1
tig_tech
tig_tech's Avatar
Trader Rating: (25)
tig_tech is on a distinguished road
Feedback Score: 25 reviews
Earl's Gangster Power Steering Hose Setup
Im sure plenty of you guys have seen this setup already but just in case you didnt this is a nice way to upgrade and relocate the plumbing of that bulky high pressure hose for the KA or SR. THIS IS FOR THE PIECE OF Earls HOSE ONLY
I still have enough hose only for 3 maybe 4 setups and need to sell them because I cant't do anything with it. All you need is the 2 steel fittings and 2 aluminum fittings for the rack and pump which you can get from a local Earls distributor or at www.summitracing.com. Either way the price is the same.
Heres the specs of the hose:
High-pressure hose designed for power steering. 2,250psi
Earl's Performance power steering hose is a triple-steel and fabric braid-reinforced high-pressure hose, developed specifically to meet the demands of power steering systems. This flexible hose is also suitable for hydraulic and air lines, and comes with a blue fabric outer covering.
Here are some pics of the setup in my car and the actual hose setup. If anyone is interested and want to save time and money let me know. I paid $40 for a 6ft length. To complete this setup I used 1'1.5". So maybe $7 for 1 piece of 1'1.5" to accomplish the setup. When I did this hole setup it cost the same as buying the oem hose from nissan or any auto parts store..freakin crazy if you ask me. So to save you money it will cost alot less since you dont have to buy it by the 6ft length like I had to from summitracing.
Part numbers/Pricing from Earls for whole setup:
EAR-130606ERL -6 POWER STEERING HOSE 6 FT. P (Which I have) $40.99
EAR-134606ERL -6 45 DEG. JIC HOSE END (For P/S Rack) $17.69
EAR-139106ERL -6 90 DEG. JIC HOSE END (For P/S Pump) $17.39
EAR-991954ERL -6 TO 14MM X1.5 POWER STEERING (For P/S Rack) $6.25
EAR-9919DFJERL -6 AN TO 16MM-1.5 ADAPTER (For P/S Pump) $10.69
Since you dont have to pay $40.99 for the 6ft length(cause you only need 1'1.5") YOU SAVE $34.00!!!
tig_tech is offline
