Old 01-23-2009, 12:02 PM   #1
nrmskate
nrmskate has a spectacular aura aboutnrmskate has a spectacular aura aboutnrmskate has a spectacular aura aboutnrmskate has a spectacular aura aboutnrmskate has a spectacular aura aboutnrmskate has a spectacular aura about
checking Fuel Pressure
Well, the problems I have been having lateley leave me and my mechanic to believe that my problem could be fuel related. He asked me to do a fuel pressure test to check it out.
So, I just wanna make sure im doing it right.
-Unplug Fuel Pump Relay
-Open gas cap
-T clamp with press gauge
-Install fuse back in and shut gas cap
-Ignition "on" and read the gauge?
I think it's right, just wanna make sure everything looks good before I possibly fuck something up.
Thanks.
nrmskate is offline   Reply With Quote
Old 01-23-2009, 12:37 PM   #2
Otto347
Otto347's Avatar
Otto347 is an unknown quantity at this point
Sounds right, it should build up the correct pressure (or not) then go from there.
I usually just get a towel and wrap it around the fuel line where im taking it apart. Pop it off and the fuel goes on the towel but guess the extra caution doesnt hurt.
Otto347 is offline   Reply With Quote
Old 01-23-2009, 12:39 PM   #3
sbc
sbc is making a name for him/her selfsbc is making a name for him/her self
With the car running pull the fuel pump fuse and let the engine die out. Open the gas cap to relieve the pressure. T your gauge into the regulated fuel line. Put the fuse back in and then start it up.
sbc is offline   Reply With Quote
Old 01-23-2009, 12:42 PM   #4
alkemyst
alkemyst's Avatar
alkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nice
Send a message via AIM to alkemyst
QFT...run it till it dies, if not you will have fuel spray.
Just an FYI you will still have fuel leaking even with no pressure, be prepared.
It'd be a good time to go to a Z32 fuel filter or at least replace your current one.
Now my Kensai, I curse you to be a Ronin and with the my remaining spirit I, beseech Chimata-No-Kami, to have you wander through time and distance lands, seeking a new master.
alkemyst is offline   Reply With Quote
Old 01-23-2009, 12:48 PM   #5
JRas
JRas's Avatar
JRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfection
Send a message via AIM to JRas
start the car
wait for it to stall
open the gas cap
undo hose/s
JRas is offline   Reply With Quote
Old 01-23-2009, 01:06 PM   #6
nrmskate
I already replaced the fuel filter.
I got the OEM 240 one.
I didn't know which z32 one to get, TT or N/A
Old 01-24-2009, 10:04 PM   #7
projectRDM
projectRDM's Avatar
They're the same.
FORMERLY R240NA
Old 01-24-2009, 11:01 AM   #8
nrmskate
Okay, well, I go to use the Fuel Pump pressure kit we have.
And every single tester kit/gauge, only reads to like 10-12psi.
And my engine default is like 34-40psi.
Old 01-24-2009, 11:10 AM   #9
slider2828
slider2828's Avatar
Yah that is low pressure.... Change fuel pump
Turn and Burn!
Old 01-24-2009, 11:13 AM   #10
nrmskate
No no no, im saying the gauge only goes up to 10-12, like, there is nothing past that, and it obviously maxes out the gauge.
Old 01-24-2009, 11:14 AM   #11
nrmskate
Like this.
Old 01-24-2009, 11:38 PM   #12
windshieldwiper
windshieldwiper is an unknown quantity at this point
fuel injected cars have higher pressures.
Like this.
windshieldwiper is offline   Reply With Quote
Old 01-24-2009, 05:18 PM   #13
slider2828
slider2828's Avatar
Wow ergh... That ain't going to work... anything from autozone?
Turn and Burn!
Old 01-24-2009, 05:31 PM   #14
nrmskate
went there, aint nothin man.
Only had one that read up to 10psi.
they had like, tire gauges that went up to 100psi and wanted to try that, but the guy at autozone said it wouldn't work.
Old 01-24-2009, 08:46 PM   #15
alkemyst
alkemyst's Avatar
autozone has them, but they are clueless. I picked one up from amazon.com cheap.
Old 01-24-2009, 08:51 PM   #16
slider2828
slider2828's Avatar
I dunno check your coilpacks... thats easy do that first.
Turn and Burn!
Old 01-24-2009, 09:08 PM   #17
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
All you have to do is:
1- remove the fuel pump fuse and start the car to relieve the pressure
(I usually just skip that step personally)
2- remove the fuel cap to relieve the pressure in the tank
(this will prevent fuel from coming out of the fuel line once you remove it)
3- loosen the clamp on the hose coming out of the fuel filter
(in the engine bay)
4- remove the hose that you just loosened the clamp on
5- use a t-fitting and a small piece of fuel hose to install the pressure guage
6- re-install the fuel pump fuser
7- start the car and read the pressure on the guage
Old 01-24-2009, 11:38 PM   #18
alkemyst
alkemyst's Avatar
i wanted to add, if you are looking for a fuel pressure gauge I bought one designed for schraeder valves and then a schrader to barb attachment. I can use the gauge for either set up now. I picked up a couple feet of hose as well...the stock setups are a bit short for our cars.
Old 01-24-2009, 11:43 PM   #19
duffman1278
duffman1278's Avatar
duffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really nice
Send a message via AIM to duffman1278
You can make one, thats what I did.
duffman1278 is offline   Reply With Quote
Old 01-25-2009, 10:31 AM   #20
nrmskate
Where did you get the gauge from ^
Old 01-25-2009, 12:19 PM   #21
duffman1278
I got that from my dad, he had an extra one at his job.
Old 01-25-2009, 12:26 PM   #22
alkemyst
alkemyst's Avatar
all you need is a 1/4" block to double barbed fitting and any guage to duplicate this. It's a really easy setup to do. I never thought about just building one and leaving it inline.
I bought this:
Amazon.com: Actron CP7818 Fuel Pressure Tester Kit: Automotive
and then some of the parts at a napa for under $10 to make
Amazon.com: Actron CP7838 Professional Fuel Pressure Tester: Automotive
