Old 02-28-2003, 10:01 PM   #1
sib16a
sib16a is an unknown quantity at this point
s13 89 240 wont start
just bought car and windows did not work so we pulled the door panels off to check the amp and found out that harness was not plugged in. we plugged it in and windows went down and never came back up. well now the car will not start. any help would be greatly appreciated. thanks
sib16a is offline   Reply With Quote
Old 02-28-2003, 10:02 PM   #2
AKADriver
AKADriver's Avatar
check your fuses including the fusible links. Unplug the power window harness in that door first though. It sounds like there's a short.
Old 02-28-2003, 10:07 PM   #3
TrueSlide
TrueSlide's Avatar
TrueSlide is an unknown quantity at this point
Send a message via AIM to TrueSlide
How long has the car sat? Have you tested the battery? Does it want to turn over? Is your clock on?
Real men drive s13s.
#240sx on EFnet
TrueSlide is offline   Reply With Quote
Old 02-28-2003, 10:22 PM   #4
sib16a
everything works just wont turnover at all. i would say it is the starter relay but i cant find the damn thing! and i did disconnect the harness afterwards. thanks
Old 03-02-2003, 02:45 PM   #5
sib16a
it was a fried ignition switch. found out after replacing a couple of relays and testing the starter.
thanks for the input.
