![]() I noticed after a few trials thats my car does not hit the redline (automatic transmission), rather it shifts at 6000rpm instead of 6500rpm. What can be the possible causes of this? How can it be fixed?
Nico |
#2 | |
Not sure if this free mod will increase the shift RPM, but it should help auto shifting in general:
![]() Join Date: May 2002
That connector is for the dropping resistor for the transmission fluid pressure regulator. Unplugging it increases transmission fluid pressure, which leads to harder, faster shifts.
But the upshift RPM isn't regulated by fluid pressure. In these cars it's regulated by the automatic transmission's computer. 6000rpm is a pretty good shift point, actually, considering the KA's stock powerband. But barring that... If you want the car to go to redline, shift it manually. |
Unplugging the regulator makes the transmission feel horrible, considering it already is a bit clunky. Behind the gas pedal there is a plastic piece. If removed will should increase pedal travel, correct? Are there any side effects to removing it?
Nico |
![]() Join Date: Mar 2002
You should be @ WOT w/ the pedal fully depressed, if you're not you need to adjust. Pulling the throttle cable more will only spin the throttle plate back into the intake stream (therefore less than WOT).
You can't get the throttle body any more open then WOT. Not that this would effect shift RPM anyway... |
The computer controls the shift points correct? Therefore possibly something to do with the codes may be faulty. How can I check for faulty codes?
Nico |
I hate to break this to you man, but your car has a truck engine in it. If you are shifting higher than 5500 rpm you are probably shifting too high. It makes its torque down low and its done by 6000 rpm. I have a manual and I don't shift higher than that, there isn't any point. The automatic computer is trying to shift at the optimal points for your car, and at redline isn' t optimal for acceleration or engine life, so it doesn't shift there. Sorry. Performance chip might let it go up higher, but like I said... no real benefit unless you are running cams or something that moved the power band towards redline.
#13 | |
#15 | |
do a little research mr blah, and check it out for yourself. Where did the handy little KA24 come from? Why does it make so much torque down low? oh, thats right. its a truck engine. flamers online are flamers in real life. |
