Old 02-26-2009, 11:14 PM   #1
InKfIx2008
InKfIx2008 is an unknown quantity at this point
Send a message via AIM to InKfIx2008 Send a message via Yahoo to InKfIx2008
Starter????? Help me!
Ok so im back once again, but with another problem hahaha. Ok so my battery was bad to begin with and I went to start my car the other day and the battery was dying,... so it finally died, to the point where it would do anything when I turned the key, but all the lights would come on like it was normal. I changed out the battery with a good one and i did the same. Even my turbo timer read something like 12.5 volts. I tryed push starting it and it started right up... Is this just the starter?? or what?? And if anyone wants to help me this weekend.... FREE BEER, BOOSE OR FOOD!! Let me know. Im located in Tierrasanta San Diego Ca
InKfIx2008 is offline   Reply With Quote
Old 02-26-2009, 11:23 PM   #2
DDDsquad_s13panda
DDDsquad_s13panda is making a name for him/her selfDDDsquad_s13panda is making a name for him/her self
From the info you wrote. its gotta be the starter. you can take it off and get it test at your local autoshop. 15-20 min. job naw'mean
DDDsquad_s13panda is offline   Reply With Quote
Old 02-27-2009, 05:53 PM   #3
Jung918
Jung918's Avatar
Jung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfection
is that 12.5 reading when the car is started or not started?
It should be around 14 when the car is started.
Jung918 is offline   Reply With Quote
Old 02-27-2009, 05:56 PM   #4
mxsx25
mxsx25's Avatar
mxsx25 is making his/her stupidity well-knownmxsx25 is making his/her stupidity well-knownmxsx25 is making his/her stupidity well-known
Send a message via AIM to mxsx25
either a bad starter or short/open from your ignition to your starter, do you hear any noise whatsoever when you turn the key over? could be a bad starter solenoid, anywho, replace the starter since im sure you can find one cheap then go from there
mxsx25 is offline   Reply With Quote
Old 02-27-2009, 06:04 PM   #5
zugoi
zugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to behold
man all you guys are dumb. someone go over there fix it, hes offering FREE BEER, BOOSE OR FOOD!!
Drunk posting FTW!
zugoi is offline   Reply With Quote
Old 02-27-2009, 09:57 PM   #6
LJBS13
LJBS13's Avatar
Trader Rating: (22)
LJBS13 is an unknown quantity at this point
Feedback Score: 22 reviews
i have the same problem i replaced the starter nd its doing the same thing! ugh
LJBS13 is offline   Reply With Quote
Old 02-28-2009, 01:07 PM   #7
InKfIx2008
Not started... when I turn the key and nothing happens it drops down to about 11.8....
Old 02-28-2009, 01:09 PM   #8
InKfIx2008
Yeah I can hear a relay click... not sure from where... I bought a used starter last night for 115 up in oc... Im going to do it today.... ill let you guys know how it goes..
Old 02-28-2009, 01:10 PM   #9
InKfIx2008
damn thats shitty im about to go out and replace it right now... i hope this fixes it....
Old 02-28-2009, 02:45 PM   #10
s13pignose
s13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of light
If it was battery I don't think you'd get anything..no lights no no nothing. But by pushing starting..any one step in if I'm wrong, but I think your bypassing the solenoid on the starter. Your doing it manually rather than by electricity. Also before my starter went out..I use to have a loud high humming noise b4 start ups. Then when I replaced it..never heard the noise again, and I'm positive it wasn't belts either. If you try cranking the car and here no sound from the starter..my guess is starter.
Good luck
s13pignose is offline   Reply With Quote
Old 02-28-2009, 07:47 PM   #11
SDS13COUPE
SDS13COUPE's Avatar
SDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant future
Yo if you need help I can help you on Monday. I don't work. Honestly it's probably something dumb.
SDS13COUPE is offline   Reply With Quote
Old 02-28-2009, 08:10 PM   #12
J240sxxx
J240sxxx is an unknown quantity at this point
...This is soo weird. iam having the same problem.. i tested the battery and it needs 800 cca and the test said 300cca so i just got a new battery.. but still nothing.. same clicking noise everything turns on but starter wont kick in.. if you guys figure it out PM me PLEASE!!!!
J240sxxx is offline   Reply With Quote
Old 02-28-2009, 08:26 PM   #13
landins13
landins13's Avatar
landins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choices
starter.....
NO HANDS IN PANTS!!
landins13 is offline   Reply With Quote
