Old 03-02-2009, 09:48 PM   #1
DDDsquad_s13panda
DDDsquad_s13panda is making a name for him/her selfDDDsquad_s13panda is making a name for him/her self
POWER STEERING PUMP FOR SR20.need HELP!!
Alright,well recently I snap my PS belt just driving around and now my pump is leaking like there's no tomorrow, drop after drop. An ive been searching and searching but no luck on interchangeable power steering from any other nissan/infinity model. Or is there? Ive read the "sr20det faq's" but no luck there, All is there is the belts and stuff.
Ive been going to the junkyard lately, and been seeing SOHC/DOHC power steering pump, but their pulleys are way bigger than my SR. Also im not sure if the brackets or the pump will fit correctly with my SR.
How bout the infinity G20 or Nissan sentra SE-R you may ask? They look so similar but the pulley agian is too big compare to mine.
Has anyone have any problem with their power steering and change it?
Ive looked at the OEM part from FRSport.com but thats a little too pricey for my pocket right now, i believe they want 299.99 for them.
A little help will be appreciated. Thanks in advance
-john
DDDsquad_s13panda is offline   Reply With Quote
Old 03-02-2009, 10:02 PM   #2
p4hang
p4hang is on a distinguished road
dude. you can use a DOHC KA and swap the the brackets and pulleys from your SR PS pump
p4hang is offline   Reply With Quote
Old 03-02-2009, 10:12 PM   #3
DDDsquad_s13panda
you are FUCKING AWESOME!!!! DUDE.. THANKS. i will grab one at the junkyard tomarrra!!!!
Old 03-02-2009, 11:10 PM   #4
pr0ject TRUENO
pr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfection
Send a message via AIM to pr0ject TRUENO
dude. having a stupid ps belt break is NOT a reason to buy a whole new pump.
you know you can just go to the auto parts store and get one right? its not like its some special part or anything.
count the grooves, measure the length with a string. any knowledgable person behind the parts counter should be able to find the right belt.
EDIT: i fail at reading entire posts.
pr0ject TRUENO is offline   Reply With Quote
Old 03-02-2009, 11:18 PM   #5
DDDsquad_s13panda
uhmm.. iono if i should flame you on this or not, but since you got the "edit" there, ill let you slide... dont get me all exciting thinking someone has something good to say but all good. btw. soon as i got my PS belt snap i grab another one from the nearest autozone but i guess going 115mph+ then your belt snapping can have alot of wrong. so i think thats what happened =/
Old 03-03-2009, 09:55 PM   #6
p4hang
an updates? it worked fine for me and all my friends with SR swaps so you should be good. and all fittings and the pulleys are interchangeable.
Old 03-03-2009, 10:46 PM   #7
DDDsquad_s13panda
not been lucky @ the junkyard. autozone sells the rebuild kit with the gaskets for the DOHC PS. so i might just try my luck on that. doesnt seem to hard. plus its only like 12.00 for the kit.
Old 03-05-2009, 02:08 AM   #8
DDDsquad_s13panda
DOHC KA, FITS my PS pump actually the same, but i need to swap out the tension bracket and pulley because the KA pulley is HUGE and will be hitting the radiator neck on the motor side.
Old 03-07-2009, 11:08 AM   #9
drifterken
drifterken's Avatar
drifterken is an unknown quantity at this point
Send a message via AIM to drifterken
have u been to the san bernardino or ontario junk yards? they have alota 240s there DOHC too... maybe u should try again since its only going to run u about 20 bucks if that... GL
drifterken is offline   Reply With Quote
Old 03-07-2009, 11:12 AM   #10
DDDsquad_s13panda
uhm... i already got it... actually for free =D
