Old 03-26-2009, 03:26 PM   #1
teamitr
teamitr is an unknown quantity at this point
s13 sr20det runing problems with codes...
so the engine is installed on an s13. the engine will turn on but not smooth and will sometimes backfire, i have checked and searched online with no luck, im getting codes 11,12,13, and 21. i know what they mean but dont know were to start, are all those components bad? or is it something else... Thanks.
teamitr is offline   Reply With Quote
Old 03-26-2009, 03:39 PM   #2
slider2828
slider2828's Avatar
lol... bad or your wiring sucks.... I think Jim Wolfe Technology has a list of codes for the SR.... but that is not good...
Turn and Burn!
Old 03-26-2009, 05:46 PM   #3
opponheimer
opponheimer's Avatar
opponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond repute
You either have a fucked up harness or don't have things plugged in or fucked your own harness up. When you're doing a wiring job you only have to extend the mafs, don't have to touch the CAS wiring, ETC wiring etc... so these are what you need to do:
1. Check ECU plug for being warped
2. Open ECU check if plug leads have snapped.
3. Unplug and Replug all connections. You might also have a key grounds missing.
4. Test somone elses ECU or have your vendor replace it free of charge.
5. Have harness examined (by me (me "soliciting"))
11 Crank Angle Sensor
12 Mass Air Flow Sensor
13 ECT Sensor
21 Ignition Signal Circuit
SR20 & RB20/25/26 in s13/s14 Wiring from $125 to $200.. Best prices EVER.
opponheimer is offline   Reply With Quote
Old 03-26-2009, 09:22 PM   #4
teamitr
So I swapped out the ecu and now I only get the codes 12 and 13, the car is runing really rich but maybe is because of the walbro pump... But i don't think that would cause does codes... also the 02 wires are not hooked up, Just incase that would have something to do with the codes.
Oh and my rpm gauge does not work, do i need to get a doch gauge cluster?
Old 03-26-2009, 11:35 PM   #5
Homer_Simpson
Homer_Simpson's Avatar
Homer_Simpson is on the path to ruinHomer_Simpson is on the path to ruinHomer_Simpson is on the path to ruin
Check your wiring like the guys above suggested yet?
Homer_Simpson is offline   Reply With Quote
Old 03-27-2009, 01:55 AM   #6
lightsource
lightsource's Avatar
Trader Rating: (41)
lightsource is an unknown quantity at this point
Feedback Score: 41 reviews
Send a message via AIM to lightsource
I think you not having your 02 wires connected is getting you rich fumes. And I'm not that knowledgeable but I think your 02 sensor is ALWAYS supposed to be connected for the car to perform...at all or correctly.
Yes, DOHC Gauge Cluster.
lightsource is offline   Reply With Quote
