Need help, ecu won't turn on.
I've been searching for hours and sent out lots of PM's but i cant find a solution.
My car is a 91 ka24de, i was having idle problems for a wile, but now my car wont turn on. It cranks but its not getting any fuel because the ecu wont turn on for some reason. I replaced the EGI & EGI pump relays twice already with no luck. I have also switched out my ecu for different one. Anyone know of any other wires, relays, or fuses i should be looking out for? Any info is appreciated. Thanks. Last thing i did before it started acting up was clean the PAIR valve. I also replaced the fuel pump 4 days before i started having this problem.
![]() Last edited by midnightouge; 04-18-2009 at 01:29 AM.. |
![]() Join Date: Sep 2005
Did you by any chance disconnect the dash plug, while swapping ecu's? My car won't start without the dash plug connected. Don't ask me how I know!
I didn't get one screw this................!
#4 | ||
This is a link to an awesome ECU diagram. I'd check all my power wires with a voltage tester, and then check all my ground wires to make sure it's all grounded.
"That's all I can say about that." Forest Gump How to pull codes from an E5 blacktop ecu...anyone know?: SR20DET Forum (rear-drive): Nissan Forums / Infiniti Forums - NICOclub ![]() |
