FS: lots of oem and aftermarket parts. Ontario Canada
- oem s13 silvia corner lights $50
![]() -oem tripple projectors headlamps $120 -oem silvia headlight brackets $60 ![]() -sr20 oem flywheel $40 -s13 front cross member $40 -s13 silvia windshield washer reservoir small! will fit with FMIC with pump $30 -s13 coolant overflow tank $20 -s14 coolant overflow tank $40 -s13 OEM sr20det injectors 370cc $65 -Greddy 52mm gauge pod for a gtr but it works good on s13 too $40 -s14 sr20 IACV $50 -s13 sr20 IACV $50 -s14 sr20 oem cams $50 -pair of s13 jdm front spindles with bearings $50 -s14 power steering reservoir $40 -s13 6 bolt left and right axles $70 pair -s13 rear lower control arms $40 each -KA starter motor $50 -KA oem injectors $50 -KA Fuel Rail $40 -s13 KA valve cover $40 -s13 KA oem cams $80 -s13 sr20 OEM rubber intake pipe $30 -s13 RHD shifter surround plastic $20 -KA flywheel $40 -silvia s13 front spindles complete with hub upright and calipers rotors and pads $120 -OEM s13 fuelpump $20 -s13 diff cover $30 -s13 brake booster $20 -s13/s14 oem engine mounts good shape $40 a pair -s13 DOHC mafs $35 -sr20 alternator $60 -s14 sr20 throttle body $30 -s13 ka24de throttle body $20 -ca18det smic with cold pipe $40 -RB20 starter motor $60 -s14 green zenki oem grill $20 -s14 oem TC rods $35 -s14 jdm drivers and passengers window switches $50 -s14 drivers and passengers window motor with assembly $60 each -s14 green power mirrors $60 for the pair ![]() ![]() -s14 jdm power folding mirrors white (no switch) $150 ![]() ![]() -sparco racing wheel got a rip in the suede $30 ![]() ![]() All parts are Located in Toronto Canada keep checking back as i will be updating this post once stuff sells and once new stuff is added |
