Old 05-29-2009, 03:32 PM   #1
fuco8210
fuco8210 is an unknown quantity at this point
Questions after alignment
s14 with stance coilovers , rucas, adjustable toe control arms.
I went to get an alignment after installing the coilovers and they told me the rear was fine and in spec. I have noticed the driver rear wheel sticks out a good amount further in the back of the wheel then the other one, is this normal to have this much difference in toe adjustment between sides? The passanger side wheel looks to sit flat and flush, whereas the drivers is tiltled out towards the back of the wheel. Can anyone clarify? thanks
fuco8210 is offline   Reply With Quote
Old 05-29-2009, 03:36 PM   #2
PinkPanther
PinkPanther's Avatar
PinkPanther is an unknown quantity at this point
Send a message via AIM to PinkPanther
Are you saying that the camber looks different between left/right sides or that the toe between sides is different? your post is kind of confusing.
PinkPanther is offline   Reply With Quote
Old 05-29-2009, 03:42 PM   #3
HYPNOTIK
HYPNOTIK's Avatar
HYPNOTIK is an unknown quantity at this point
Send a message via Yahoo to HYPNOTIK
It probly is within "spec". The last time I payed for an alignment was when I swapped my subframe, it was worse after I got it back than when it went in but it was still within "spec". Now I do my own alignment and don't have any problems. If you don't have that option then take your car to someplace better to get an alignment, is there someplace that specializes in performance alignments in your area?
HYPNOTIK is offline   Reply With Quote
Old 05-29-2009, 04:31 PM   #4
fuco8210
The toe arm is adjusted a good amount further outwards then the other side and the wheel looks alot more slanted
Old 05-29-2009, 04:44 PM   #5
tire_machine
tire_machine is an unknown quantity at this point
i've wondered about camber differences between driver/passanger sides often.
I've never had my car aligned, just slammed it, and drive like that.
i'm sure there is a way to adjust rear camber manually, just haven't gotten around to finding out how
tire_machine is offline   Reply With Quote
Old 05-29-2009, 04:49 PM   #6
HYPNOTIK
HYPNOTIK's Avatar
There is a cambolt on the UCA just like the toe arm. It doesn't have much adjustment in it so aftermarket arms make things easy.
