Old 05-29-2009, 03:53 PM   #1
dongoesby
dongoesby's Avatar
dongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of light
Max power gain for SR bolt-on parts
Just curious and anxious to know how much power that my bolt-ons are going to put out on the stock s14 sr motor. Since this is my first step of getting healthy reliable power, I'm have following bolt-ons and not planning for any management/tuning yet.
HKS actuator (thinking maybe stock boost or ~10psi)
Tomei manifold
Circuit Sports turbo elbow + downpipe (2 in 1 design)
JIC full titanium 3" cat-back
Cusco cold pipe
Stock hot pipe (looking for an aftermarket one)
S15 SMIC
Stock recirculate bov
Walbro/Tomei fuel pump (still deciding)
Exedy lightweight flywheel
Greddy oil pan
NGK Iridium spark plug
Nothing big. What do you guys say? Maybe another 30~40hp? Any chance of hitting 220whp?
The motor is being refreshed with new nismo thermostat, water pump, gaskets, new rubber hoses, belts and new RTVs.
Compression test was decent when I bought the motor: 145-140-145-150
dongoesby is offline   Reply With Quote
Old 05-29-2009, 04:05 PM   #2
Sileighty_85
Sileighty_85's Avatar
What turbo are you running?
If its a T25 you'll get around 240ish (Safe Max 14psi)
T28 your probably looking around 260-270ish depending on boost levels (safe is 14-15psi) although some ppl make close to 300 but that with Cams and a tune
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 05-29-2009, 04:50 PM   #3
dongoesby
dongoesby's Avatar
S14 SR motor w/ T28 HKS actuator stock boost ~ 10 psi
what you think?
Old 05-29-2009, 04:53 PM   #4
slider2828
slider2828's Avatar
You aren't really doing too much for gains. You might get like 30HP er so on top of stock.
Turn and Burn!
Old 05-29-2009, 04:54 PM   #5
Sileighty_85
that side mount is gonna kill you, yeah the S15 S/M a little bigger, but it will still heat soak.
10psi probably looking around 230ish
後輪駆動車1番
1986 SR86 - 200ish
Old 05-29-2009, 05:19 PM   #6
murda-c
murda-c's Avatar
Tuning is the best bang for your buck.
Old 05-29-2009, 06:17 PM   #7
dongoesby
dongoesby's Avatar
went out of bucks for buying the motor and preping the motor
so i guess with all these parts, it is bring me ~240-250hp not the wheel.
that is harsh!
Old 05-29-2009, 06:25 PM   #8
Sileighty_85
that is harsh!
It will be at the wheel but probably no higher than 240
後輪駆動車1番
1986 SR86 - 200ish
Old 05-29-2009, 07:24 PM   #9
Silverbullet
Silverbullet's Avatar
Silverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really nice
Send a message via AIM to Silverbullet
They both have 370cc injectors. 240WHP-ish is the most i'd be expecting running safely.
HouseBuyers365.com
Originally Posted by Flybert
Go back to whatever Honda forum you came from.
Silverbullet is offline   Reply With Quote
Old 05-29-2009, 07:40 PM   #10
Sileighty_85
Haha right I was thinking if he had some 550's and an SAFC
Here's a thread I made a while ago, mine was a Red Top with a T28 and page 2 has a dyno graph from 95KA-Turbo and his S14 SR Dyno
http://zilvia.net/f/tech-talk/194503...jectors-2.html
後輪駆動車1番
1986 SR86 - 200ish
Old 05-29-2009, 07:57 PM   #11
Def
You'll be injector limited, so about 250 rwhp or so safely. It'll probably hit that around 12-13 psi.
I made 205 rwhp with a stock redtop with just a turbo back exhaust(Trust outlet pipe, 3" from there) and stock boost(about 9 psi after the exhaust). So you should be much higher than that with a T28 and a few more mods and boost.
Old 05-29-2009, 08:00 PM   #12
95KA-Turbo
95KA-Turbo's Avatar
95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of
Yeah the injectors are the biggest thing holding you back, followed by the MAF, and before both of those a tune.
I am making ~235whp SAE corrected on 10psi.
With some sort of tune and S15 injectors I am hoping for ~270-280whp. I've got to get some more expendable income to do that though.
Instagram - SJKnoop
95KA-Turbo is offline   Reply With Quote
Old 05-29-2009, 08:17 PM   #13
waynehead05
waynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura about
Send a message via AIM to waynehead05
If I were you I'd try my best to grab an Ebay intercooler setup. It's going to be better and safer than the sidemount. You can snag them pretty cheap sometimes.
If nothing else really consider it.
Who in their right mind would want to lead this nation of Me-First Right-Now Do Nothings??
waynehead05 is offline   Reply With Quote
Old 05-29-2009, 08:19 PM   #14
dongoesby
dongoesby's Avatar
woo nice, do you think s15 smic would be sufficient enough for above 240whp?
Old 05-30-2009, 07:46 AM   #15
0wn3r
0wn3r's Avatar
0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of
why get a tune then mess w/ the motor more tho and have to tune again?
97 240sx se
0wn3r is offline   Reply With Quote
Old 05-30-2009, 07:56 AM   #16
johngriff
johngriff's Avatar
That is why you get a programmable engine managment system like the haltech.
And just with the stuff listed off, you are looking at 210 @ a dynojet and maybe 189 on a dynodynamics.
All your exhaust upgrades have done for you is let you run allot more "flow" out the exhaust, but at 10psi, there is probably no difference in numbers vs stock exhaust, if anything the larger piping is probably hurting mid-range tq.
The other thing you can do is now get more timing out of the engine before knocking, so its something to consider (getting a programmable tuning platform like the Haltech EMS)
[email protected]
Old 06-03-2009, 11:39 AM   #17
95KA-Turbo
95KA-Turbo's Avatar
It would be kind of sketchy, you'll be losing power/dealing with heatsoak over 10-11psi on a SMIC...whether it be a S14 or S15 SMIC (I've heard the S15 one is a little better). ARC, Blitz, and I believe HKS made upgraded SMICs that are much thicker and let you run more boost.
If you can make your own piping look into a Evo 8 FMIC. I got mine for dirt cheap and it fits perfectly in where the AC condensor used to be....it also fits great up front and allows you to still keep your fog lights should you want an actual front mout intercooler.
Instagram - SJKnoop
Old 06-03-2009, 12:12 PM   #18
Monooxide
Monooxide's Avatar
Monooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to beholdMonooxide is a splendid one to behold
I made 273 WHP and 280 WTQ on S14 SR. Stock Turbo, Injectors, ECU and MAFS. Full bolt ons and FMIC.
12.6 PSI and Leanest AFR of 12.2.
Monooxide is offline   Reply With Quote
