Old 07-09-2009, 09:08 PM   #1
BustedS13
BustedS13's Avatar
Question off-car injector cleaning?
i think this is my third failed injector. clearly, just seafoam isn't doing the trick. what's a good way to clean injectors out of the car, aside from sending them somewhere for cleaning?
i'm thinking about buying a cheap ultrasonic cleaner and pulsing them in a vat of seafoam or rubbing alcohol.
Old 07-09-2009, 10:21 PM   #2
datboibrad
datboibrad can only hope to improve
the question is why are you killing injectors. if your constantly clogging them then figure out what part of your fuel system is contaminating the injectors. could it be a old dirty fuel filter your neglecting to change? similar situation with the fuel pump strainer maybe? hell could easily be the fuel tank rusting from the inside out. ive had all three things cause problems with my injectors.
datboibrad is offline   Reply With Quote
Old 07-09-2009, 10:22 PM   #3
BustedS13
BustedS13's Avatar
first one was on the first engine back in 2001, second one was somewhere between, this one just happened.. i think it has a lot more to do with age than anything.
Old 07-09-2009, 10:31 PM   #4
datboibrad
so this isnt all on the same engine. that helps and hurts this situation at the same time. you need to fid out what these situations all have in common. is it the same number injector each time? possibly suggesting a bad connection in the wiring harness or something to that nature. these are the things you need to investigate at this point.
Old 07-09-2009, 10:37 PM   #5
BustedS13
BustedS13's Avatar
nah. everything's been changed out at some point or another. this is the third engine. new fuel filter somewhere after the second one died. different cylinder each time, i think. maybe #3 twice. either way the harness has been completely removed and cleaned up. i'm getting proper voltage at the dead injector. i honestly think this is more of a 20 year old injector problem than anything else.
Old 07-09-2009, 10:40 PM   #6
GSXRJJordan
GSXRJJordan's Avatar
I can't think of any way to clean them better than the fuel rail does already - I'd send 'em out, it's not that expensive, and then you know it's perfect.
Old 07-09-2009, 10:48 PM   #7
Ragnarok043
Ragnarok043 is making a name for him/her selfRagnarok043 is making a name for him/her self
im pretty sure there are fuel injector cleaning kits that hooks up to the fuel line with pressurized solvent, not those gasoline additives. not sure where you can find them though. another option is that you can send them here Fuel Injector Cleaning and Flow Testing - Fuelinjectorclinic to get them cleaned.
Ragnarok043 is offline   Reply With Quote
Old 07-09-2009, 11:20 PM   #8
BustedS13
BustedS13's Avatar
Reported Attack Site!
This web site at Homepage Fuelinjectorclinic has been reported as an attack site and has been blocked based on your security preferences.
Attack sites try to install programs that steal private information, use your computer to attack others, or damage your system.
Some attack sites intentionally distribute harmful software, but many are compromised without the knowledge or permission of their owners.
Old 07-10-2009, 12:23 AM   #9
Ragnarok043
okay NVM then, but im pretty sure theres plenty of places you can send to have them cleaned
Old 07-10-2009, 03:07 AM   #10
aznpoopy
aznpoopy's Avatar
recommended by rx7 people. here at least.
KGParts.com - Fuel Injector Cleaning & Flow Testing Services
here's the direct site for their injector service.
http://injector-rehab.com/index.htm
$16/injector, they ship them back to you for free if you send in four, and will even take a video of the testing/cleaning if you're willing to pay for it.
Old 07-13-2009, 01:45 AM   #11
superbraut
superbraut is an unknown quantity at this point
deleting .
deleting .
superbraut is offline   Reply With Quote
Old 07-14-2009, 12:36 PM   #12
trust hks
trust hks's Avatar
trust hks has a brilliant futuretrust hks has a brilliant futuretrust hks has a brilliant futuretrust hks has a brilliant futuretrust hks has a brilliant futuretrust hks has a brilliant futuretrust hks has a brilliant futuretrust hks has a brilliant futuretrust hks has a brilliant futuretrust hks has a brilliant futuretrust hks has a brilliant future
KG Parts is good people.
I've used them 2-3 times with outstanding service, and great turn around time.
jnkhse
trust hks is offline   Reply With Quote
