Old 09-27-2001, 12:09 PM   #1
stl240
stl240 is an unknown quantity at this point
what size are the stock injectors on the s13?? Where can i get larger injectors, and how much you think theyll be?
stl240 is offline   Reply With Quote
Old 09-27-2001, 01:09 PM   #2
Freak Leash 240
Freak Leash 240 is an unknown quantity at this point
Send a message via ICQ to Freak Leash 240
Stock KA24 injectors are 285cc, if you want an easy upgrade you can get Nissan 370cc injectors from a 300ZX and they'll drop right in, they should run around $100 new, or you can just get them refurbished for much less
If you want anything bigger than that, I'd try RC engineering http://www.rceng.com or MSD <a href="http://www.msdignition.com
Keep" target="_blank">http://www.msdignition.com
Keep</a> in mind, for ANY injector upgrade, you have to get your ECU reprogrammed by Jim Wolf Technology ($600) http://www.jimwolftechnology.com
(Edited by Freak Leash 240 at 11:11 am on Sep. 27, 2001)
(Edited by Freak Leash 240 at 11:12 am on Sep. 27, 2001)
Freak Leash 240 is offline   Reply With Quote
Old 09-27-2001, 01:34 PM   #3
ditosx
ditosx is an unknown quantity at this point
is that only true for the ka24d? &nbsp;Or can it drop in to both the single and dual overhead cam?
ditosx is offline   Reply With Quote
Old 09-27-2001, 03:21 PM   #4
Freak Leash 240
Now that I don't know... may fit.
Old 09-27-2001, 11:06 PM   #5
nguyen
nguyen is an unknown quantity at this point
I think the 89-90 s13 use top feed injectors, and the 91-98 use side feed injector and they are 270cc not 285cc
the injectors from a sr20det 370cc, vg30dett 370cc will bolt right in, but it will require an ECU reprogram. again I am not too sure about the 89-90 model if it is top feed or side feed
nguyen is offline   Reply With Quote
