Old 08-12-2009, 06:12 PM   #1
biggbadd240sx
biggbadd240sx is an unknown quantity at this point
s14 stuck brakes NEED HELP
hi im josh i have a 96 240sx with auto to 5 speed so im still using the auto brake booster and MC but i did the swap like 2 to 3 months ago and i just started to feel this in my car..... when im driving sometimes the pistins dont retracked, so i slow down with out pressing the barkes, and i cant accelarate that good either, so if you can help me then pm me or post please, waisting gas lol
biggbadd240sx is offline   Reply With Quote
Old 08-12-2009, 06:17 PM   #2
gripDRIFTschassis
gripDRIFTschassis is an unknown quantity at this point
I had that problem with the brakes last year. I had to pull over and pop the hose out to relieve the pressure from the booster and put the hose back. And it was fine for an hour or two. turns out it was the booster. Not sure if thatll work with you. Try pulling the hose and putting it again.Also check the check valve.
gripDRIFTschassis is offline   Reply With Quote
Old 08-12-2009, 06:22 PM   #3
biggbadd240sx
thanks man ill try it hopefully it works later
Old 08-12-2009, 06:53 PM   #4
onehundredoctane
onehundredoctane's Avatar
onehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfection
is it just on one corner? or just the front? just the rears?
my guess is if it's just one corner your either gonna have to rebuild the caliper or replace the soft line on that corner would be my guess
onehundredoctane is offline   Reply With Quote
Old 08-12-2009, 09:48 PM   #5
biggbadd240sx
no its either all of them or just the front at lease. you think its the booster??
Old 08-12-2009, 09:52 PM   #6
l33tmonkeyman
l33tmonkeyman is an unknown quantity at this point
Send a message via AIM to l33tmonkeyman
if it relates to all the brakes, my guess would be the booster
l33tmonkeyman is offline   Reply With Quote
Old 08-12-2009, 09:56 PM   #7
WangonwWarrior
Location: Amerika24 alabama: Where if your not first..... your last
WangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant future
do this:
bleed front brakes thoughly if that does not work you might have stuck pistons so then remove front calipers and see if you can compress the piston with big channellocks with bleeder open you have to be a man and squeeze hard so hit the gym with the meatheads first. if they dont compress you prob should invest in new ones orr just get z32 front setup have a nice day
WangonwWarrior is offline   Reply With Quote
Old 08-13-2009, 07:59 AM   #8
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
There's a one way valve on the brake booster to intake line
make sure it's still working or on the right way
Old 08-13-2009, 11:57 AM   #9
zylvia213
zylvia213's Avatar
Trader Rating: (36)
zylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond repute
Feedback Score: 36 reviews
Send a message via AIM to zylvia213
From what i know if your booster is bad you'll just have a hard brake pedle... but just check the 1 way valve first. I would drive it around the block for a while then when you start feeling the brakes lock go back home jack it up. Then spin the wheels and see which one's are stuck. If its only one thats stuck then might just be that one caliper, if all the wheels are stuck you gota start trouble shooting to see whats causing all the wheels to lock. Do a brake flush and bleed the whole system. so how it goes
zylvia213 is offline   Reply With Quote
Old 08-13-2009, 12:37 PM   #10
Touge Noob S13
Touge Noob S13's Avatar
Touge Noob S13 is making a name for him/her selfTouge Noob S13 is making a name for him/her self
I to had this problem a little while ago, did most of what was listed above but it did not work. I got a new BMC and the problem went away although the old BMC seemed to work fine and all but apparently it had gone bad.
The things people will do for a green card.
Touge Noob S13 is offline   Reply With Quote
Old 08-13-2009, 09:16 PM   #11
biggbadd240sx
ok thanks everybody ill try checking everything that i can to see what is the problem later
