Old 10-28-2009, 07:21 AM   #1
isimon91
isimon91's Avatar
isimon91 is an unknown quantity at this point
Send a message via AIM to isimon91
T3/T4 Garrett Turbo, Manifold, WG, Downpipe
Shipping: At buyer's expense
-T3/T4 .57trim 60comp Garrett Turbo ($350)
Minimal shaft play, ran fine and pulled strong.
-Peakboost Top Mount Manifold w/ 38mm Tial External Wastegate for SR20 ($600)
This is a top mount manifold, with the Tial wastegate welded onto the manifold.
-Peakboost 3" Stainless Downpipe ($250)
3" peakboost top mount downpipe for a top mount turbo (used in T3/T4 setup).
-SR20DET 370cc Stock Injectors w/ fuel rail and FPR ($200)
Worked well before removed, low mileage. I upgraded to larger injectors.
-Greddy BOV ($75)
Worked fine when it was on the car
-Greddy SR20DET Intake Manifold ($400)
-SR20 Nismo Motor mounts ($100)
-Stock SR20DET radiator w/ Nissan Electric fans ($135)
Never overheated, ran fine for two years on my SR swap.
-VMount Intercooler setup.. pm for pricing
Comes with C&R import racing radiator w/ single electric fans, custom radiator hoses (includes extra lower hose), modified greddy coolant surge/fill tank painted sparkly black w/ new rad cap, modified Greddy M spec intercooler core (painted black), steel hot pipe w/ nipple for wastegate hose, aluminum greddy flanged cold pipe
-OEM S13 Shortblock ($150)
Has bad rings, needs a honing, perfect for a rebuild project.
-OEM SR20 Flywheel ($50)
Needs a light resurfacing, comes with all flywheel bolts.
-OEM S13 Suspension($150)
OEM Springs/Struts, no issues, drove fine.
-OEM S13 FLCAs ($30)
OEM S13 Front lower control arms, good condition, ball joints are slightly worn and should be replaced.
-OEM S13 RUCAs ($40)
No issues, selling b/c I needed adjustable rear camber.
-OEM SR20 O2 Sensor(Make an offer!!)
-OEM SR20 Transmission Gasket (Make an offer!!)
-OEM SR20 Pulleys ($80)
Will include pulley belts for $20
-OEM SR20 Bell Housing Bolts (Make an offer!!)
Bolts that connect the SR transmission to the block
-Greddy FMIC Kit for T3 Turbo ($200)
No issues, FMIC needs slight repair, bent mounting bracket. Easy fix with some JB weld.
-Aluminum racing radiator with 2inch core ($150)
No issues, fits S13 engine bay perfectly. Needs custom mounting brackets.
-OEM S13 Tie Rods
Never had a problem, came on a steering rack that I swapped onto my car.
If you have any questions, feel free to email me at [email protected] or PM me.
Pictures:
If you're interested, the best way to contact me is by email, @ [email protected]
1993 S14 SR Powered Hatch: Sold
1989 S13 SR Powered Coupe: Money pit
isimon91 is offline
