Old 11-23-2009, 03:35 AM   #1
asiandude15
asiandude15 is an unknown quantity at this point
s13 KA24DE high idle and not wanting to start
Alright, so first off my car was running absolutely fine a couple days ago before any of this stuff started happening. So, my car was absolutely fine and then I parked for like 5hrs a few days ago. I go to start it it doesn't want to start. I don't touch it till morning when the sun comes out and then I pop the hood and try to start the car to figure out the problem. Then to my surprise the car starts right up. A couple of days pass and about midday I go to turn my car on and then all the sudden the idle is incredibly high like 1300 to 1500. I literally can let go of the clutch completely in 1st gear and the car will move and not die! I'm like what the heck is going on, so I check my throttle cable and check to see if I have an air leak anywhere. Eveything checks out then I go and park the car. I come back about 1hr later try to start it. It turns on bit doesn't stay on for even 10 seconds and only goes to about 500 rpm and does. Then I crank it again and it doesn't want to start so I crank it and crank it for about 30 seconds to 1 minute an then it starts very roughly before high idle again. So, as of right now it's been doing this, I've had to crank it for about 30 seconds to 1 minute before the car starts roughly and idles high. Anyone have any ideas whats wrong? I've checked my throttle cable and no air leaks anywhere. The motor is bone stock!
asiandude15 is offline   Reply With Quote
