Old 11-11-2009, 12:21 AM   #1
yudalicious
yudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond repute
FS: S14 Koni/GC setup
My loss is your gain. Everything (except when noted) is brand new, never even mounted on a car.
Front:
-S14 Koni yellows already inserted into stock tubes
-7" 400# 2.5ID Hyperco springs
-Ebay special camber plates
-TechnoToyTuning upper hats
-Ground Control bump stops, already trimmed
-Roller bearings on the bottom of the springs
-Most of the miscellaneous hardware, just need another small sleeve
Rear:
-S14 Koni yellows rebuilt and revalved to handle 300# at the minimum setting (tried to convert to externally adjustable, but Koni does not have a hollow rod long enough at the time)
-7" 300# 2.5ID Eibach racing springs (used)
-Ground control bump stops
-TechnoToyTuning top hats
-You can either use a stock top mounting solution or use aftermarket such as the Tein top mounts
Misc:
-a **** ton of random sleeves, washers
-a few more TechnoToyTuning upper hats
-a pair or two of used 5" Eibach racing springs, I don't remember off the top of my head the specifics, probably not very helpful for 240 setups.
Located in Atlanta/Gwinnett. At this time I am entertaining local offers (packing and shipping will be a pain and expensive) and am not parting out. Asking for $900 firm. I spent at least $1200-1300 collecting everything, the small stuff really adds up. If you are not local and are interested, email me maybe we can work something out.
PLEASE EMAIL [email protected] that is the easiest way to reach me I don't check forums often.
yudalicious is offline   Reply With Quote
